Suspension looks to be Tilted to the Left!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by SoCalBPrius, Jan 10, 2012.
  1. SoCalBPrius
    SoCalBPrius Active Member
    563
    118
    SoCal
    Hey guys, just want to 1st say that this is a awesome forum where I learn alot & get tons of good information, so Thank You to all the members & those affiliated w/ Prius Chat & I hope I can make some contributions to pay it forward :). With that being said, has anyone noticed that the left side of their prius is slightly lower than the right or is it just me(my prius):D? My theory is that since there's more weight on the left side, it has sagged alittle over to that side. I would love to hear comments & opinions.
  2. NineScorpions
    NineScorpions Economy, Meet Style!!
    375
    64
    This is true on my Pri. I was measuring when installing my wheels and then my new springs. In all three instances (stock, new rims, new springs)...the left side of the car is anywhere from one quarter to one half inch lower. Keep in mind I am measuring from the top of the fender to the ground. Not noticeable...so just information I suppose. I did see one post on here where the tilt was quite noticeable however...you would have to do a search to find it.
  3. SoCalBPrius
    563
    118
    SoCal
    Hi 9scorpions, luv yor setup btw as there's some similarities in our upgrades such as drag wheels & eibach but I promise I didn't try to copy:). As for the subject were on, thanx, I was beginning to think I was the only one:eek:. I didn't measure the gap difference but to my discerning eyes, I would approximate it @ about a 1/4 of an inch higher on the right front compared to the left front & 3/8-1/2 inch higher on the back right compared to the back left wheel well area. The funny thing is most people don't really know/or can't tell even when I point it out to them, they say "it looks fine" or "looks same" but I've been seeing it for quite awhile, don't know exactly when but since stock height(which was actually more noticeable before the drop). It's jus good to know someone else is going through this as it makes me think I didn't get a lemon;).
  4. NineScorpions
    375
    64
    thanks man...same to you. I like your wheels...the two cars definitely look very similar. The only reason why I found out is because of the measurements which were intended to understand height difference with the changes. I honestly have not stood in front of or behind the car to check. And now I will not...cause I will likely see it and it will bug the crap out of me...lol.
    on a side note...what mpg you pushing with your setup? I just bought mine...so I have to assume I will see some slight improvement in mileage when it warms up.
  5. SoCalBPrius
    563
    118
    SoCal
    Haha, yep, I wish I didn't know about it either as I'm kinda anal about those things too & jus luv the new lowered look as I got the springs a week ago & got it installed past sat. & had the rims about a month ago so don't have too much mpg info. w/ wheels (about 1 1/2 full tank worth) but have estimated so far about 5-6 miles less than what I've been getting before the tire-wheel combo. So currently about 45-46 estimated mpg whereas I had a solid 51.2 calculated mpg w/ my previous stock setup(9 fillups). But, the estimated value could be somewhat skewed so I'll keep u updated as we're both in the trial & learning stage right now. I feel like I have a new(er) prius:D.
  6. kochusan
    kochusan New Member
    38°40'23"N 121°31'03"W
    I noticed this on mine as well. The left rear is 1/2" lower than the right rear (measured from ground to fender lip and from hub to fender lip). I was contemplating lowering springs when I noticed this.
    Looked under the rear at the springs and measured the compression of the coils. Lo and behold, the left spring was compressed more at each coil than the right. Being the curious type - really just wanted to see how difficult it would be to change springs, I swapped the left and right springs. The difference was still there.
    At first, I was thinking one of the springs was sagging but swapping them ruled this out. Only thing I can think of is that the left side is heavier. I've seen quite a few other Prii (sp?) with the same listing appearance. There is a thread somewhere here about an irate '10 owner with the lean.
    Maybe coilovers will level it out.
    Found link but won't let me post it: priuschat.com/forums/gen-ii-prius-main-forum/52014-inspect-very-carfully-before-purchasing.html
  7. SoCalBPrius
    563
    118
    SoCal
    So this could be a more common problem than I originally thought, as that was my first thought that it might have sagged or worn down as I drive alone alot & even when I don't I'm heavier than my wife. Like u, I thought this stance would even out after the recent spring change but no it didn't. Hmm, I'm more curious than ever on why:confused: as coilovers for me is not an option because of the cost.
  8. swaggingprius
    swaggingprius Member
    88
    29
    East Coast
    Hello, I personally had not noticed that the left side is lower than the right, but that makes me think about my experience after installing coilovers.
    I rub every now and then left front tire only, even though both sides "should" be equally as low. Just reading this thread makes me wonder and want to go back measure gaps on all 4s.
    Since I do have coilovers, maybe I can adjust the left side to go a bit higher than right to compensate the extra weight. I mean, the issue is so much more weight on the left that it seems off compared to the right, right?
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    I'm surprised no one mentioned this, but it is a commonly known fact that most Prius owners lean to the left; some are way out to the left. Most likely this has caused a bias in the suspension system.
    Tom
  10. Jaquimo
    Jaquimo Paraglider, Prius glider...
    96
    38
    Bloemfontein, South Africa
    I measured my Prius' heights and the left side is about 5mm (1/4") higher than the right side. Since all the previous posts were from people who drive on the right (wrong :D) side of the road I think that the height difference may have something to do with the camber of the road. The passenger side being higher than the driver side may compensate for the road being lower on the passenger side? Perhaps members from other countries who drive on the left side of the road could check also?
  11. Jon760
    Jon760 New Member
    Hi I am new to this forum. I bought my new Prius two weeks ago. I have the same issue with the rear driver side being noticeably lower. I began to notice at 300 mi and I thought perhaps it's the not-so-leveled pavement. I already logged to date 700 miles but prior to driving it this morning, I finally took a meter stick and here's photos of the rear left and right wheels.
    The photos are all in centimeters as pictured and measured up to bottom of fender. The left rear is about 26.3 inches equivalent (sorry can't use html link as of now). Second thumbnail for right rear is about 27.25 inches equivalent.
    I took it to the dealership today but because it's 90s in San Diego right now and dealership was 30 miles away, the tires obviously have expanded. Dealer measured and the left is in fact lower but not so much. It was 26.9375 on the left rear and 27.125 on the right a difference of .1875. Both rear tires have the same pressure at time of measurement
    So should I ignore it and digest the fact that it is a common problem?
    Thanks for any thoughts
  12. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,455
    92
    Looks to me like your tire diameters are the same. The difference appears to be the suspension ride height.
    In both cases the edge of the tread is at 60cm -- constant tire diameter.
    Looks to me like one strut is riding with 2.5cm more extension than the other.
  13. varun singh
    varun singh Member
    113
    Wayzata
    I noticed this today too, It is definitely tilted at left,..
  14. Mendel Leisk
    38,652
    Me too. I know from experience when putting jack stands on the rear: always check if it's raised enough on the driver's side, the other side will have plenty of clearance. FWIW: our previous Civic Hybrid was the same. Maybe due to one person driving the car, putting more weight on the suspension on that side? Road camber doing something?
  15. varun singh
    varun singh Member
    113
    Wayzata
    I think it may due to hybrid components heavier on left side, that would be sound right as so many peoples are seeing same thing
  16. Mendel Leisk
    38,652
    The Civic battery was more on the drivers side I think. The Prius battery is pretty much balanced, maybe a bit more toward drivers side. The 12 volt, which weighs around 26 lb, is on passenger side, way in the corner.
  17. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    As a large man I can say this, if the booty is big the car will lean while in it and then after a few years on its own.
    I've had this issue on all my vehicles I've owned. From cars to trucks to Prii to TCHs...
    Hell, one of my old 1984 Honda Civics DX HB I had to put a special lift on the drivers side cause it leaned so much when I got in.
    The only car I think that didn't have this issue was my 1976 Ford Thunderbird, 460 cu in V8 dual carborator (8b) gas guzzling polluting behemoth. That thing was a tank and I don't think anything could have messed up that suspension.
  18. C-Dawg
    C-Dawg New Member
    NH
    My 2015 Prius noticeably (1” difference) tilts down on the driver side. I’m a 115 lb female, have driven car 110,000 miles, so I don’t think driver weight is the cause. Dealer said shocks ok, but still a tilt problem. Will try to find an independent trustworthy mechanic (is that a contradiction of terms?!)
  19. Hybrid Hound
    Hybrid Hound Junior Member
    35
    17
    South West Florida
    Just had to measure the height after reading this. Owned for 5 years this September and never noticed the 1/2" difference in height on the drivers side (lower). Less than 50K on the car, we are both average weight folks. Anyone ever figured out why the discrepancy? Most interesting. Will measure when we pull our camper next time, the tongue weight is 150 pounds. I keep the tires at least 35 PSI, then bump them up to 38-40 when I tow. Very strange!!
  20. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    Prius just has its own gansta lean.............to cool except for the cool to notice! Subaru ain't got nothin on this lean........LoL
