Suspension upgrades?
Discussion in 'Gen 3 Prius Main Forum' started by Zeus661, Mar 8, 2014.
  1. Zeus661
    Zeus661 Junior Member
    36
    What suspension upgrades has anyone done and what was the difference? What part and what brand did you add? Did you do it yourself? How difficult was it?
    Excluding lowering
    TIA
  2. priusdonkey
    priusdonkey Member
    211
    51
    Los Angeles, California
    Tires - cheap fix. made the econocar cooperate while i am driving the Prius JBox. Before the fix it was modestly vague steering with the Good-for-a-year Fuel Max. The Bridgestone Ecopia422 definitely improved the handling and traction. Will probably put in a rear sway bar, after i pay off my Amex.
  3. priusrick
    priusrick Member
    257
    40
    lowering springs, cross brace and rear sway bar are what I'm looking into.
  4. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    Added in a TRD/Plus RSB and swapped in an OEM RAV4 FSB. The RSB is easy. The FSB requires unfastening of one of the swingarms.
    RSB came first and although had a significant effect in limiting body roll, the car felt 1) unbalanced, rear axle felt obviously more resistant to roll than the front, and body attitude was determined predominantly by the rear axle; and 2) the rear felt more tossable than I'd like in a car with a very disconnected throttle and no torque.
    FSB came quickly in response to that. Addressed all of the issues raised by the RSB except that the car has returned to near-stock tossability, a little more tossable rear (but less than with just RSB) would be nice. The Prius is not a car I would always try to weight-transfer into a corner (runs antithetical to the idea of fuel efficiency) except on a downhill... so I have to more wary of entry understeer.
    Months later the bushings have worn-in and softened, and the ride is great. The only remaining issue is that increase in side-to-side spring rates would benefit from uprated shocks, for which I'm waiting.
  5. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I have:
    1. TDR rear sway bar part number PTR11-47010
    2. generic mid chassis cross brace from Ebay (made in China)
    (this might be optional on a 2013 since it has a improved stock mid-chassis from my 2010)
    3. a Sustec front/mid "under brace" TUB153F chassis cross brace from Amazon. Incorrectly listed as a "Rear brace" on the Amazon page.
    (this might be optional on a 2013 since it has a different/improved front mid-chassis from my 2010)
    I did them all myself:
    1. rear bar - best done while jacked up and on two jack stands. Much easier to bolt in the end links if you can take the wheels off.
    2 and 3 You can bolt them while laying on the ground. If your over 200 pounds you might not fit.
  6. 1Prius4u2NV
    1Prius4u2NV New Member
    Phoenix, Arizona
    <~~~ plus edition
    Perfection at its best!
    iPhone ?
  7. Burna J
    1,064
    3,334
    53
    Long Beach, CA.
    I've been very happy with my Cusco suspension up grades. Nice and solid in the turns...
    sorrywereclosed likes this.
  8. DadofHedgehog
    DadofHedgehog Active Member
    681
    281
    northern Virginia
    Mike500 likes this.
  9. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    FWIW, I'm looking into installing a TRD (or similar) rear sway bar...if the price is right.
    However, the SAME money will pay for a LOT of gasoline...
