suspicious noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by blackmasked, Nov 30, 2015.
  1. blackmasked
    blackmasked Junior Member
    London, UK
    Hi there
    I have recently purchased a 2007 Gen 2 Prius and sometimes it emits a very annoying squeak. It occurs when the car is stationary, with the brake pedal fully depressed. When inside the vehicle it seems to be coming from behind the glove box. When on the outside and facing the car it seems to be coming from below / behind the electric motor. I have made a recording of it with the noise in question being audible for a couple of seconds at 0:13, and then again at 0:22 until the end. It could be nothing I guess, but this is my first hybrid and I am not too sure what is perfectly normal and what is not.
    Any suggestions?
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Do you mean the buzzing noise from brake pressure pump? It’s normal. It pressurizes brake pressure accumulator, where pressure can be taken to apply brakes when needed. You do get used to the sound.
  3. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    The rattlesnake-like sound is the brake pump but you're probably referring to that rhythmic sound like a squirrel jumping on an old car or something. That's a weird one--I've never heard it. It doesn't sound normal. Is the climate control blower on? If so, there could be something interfering with its rotation? You could try removing the cabin air filter and inspecting. Open the lower front passenger glovebox, squeeze the back of the sides to release the holding pins from the dash, undo the little plastic strut on the R-side and let the glove box lower completely. Then locate the rectangular, white plastic panel with two latches, hold the latches open and pull the panel out toward you. Then you can inspect the blower (and change/clean the cabin filter).
    Oh, does it stop when you release the brake pedal? If so, it's probably not the blower motor. Maybe someone else knows...
    49,735
    welcome! is it the brake honking sound?
  5. blackmasked
    London, UK
    I was referring to the 'squirrel' sound, not the buzzing sound.
    It sounds like a rotating part that rubs against something once per revolution.
    As soon as I take the foot off the brake pedal and the car starts to move, the noise goes away.
    Air con was off when I made the recording, but I think I will still remove the glove box and see if I can get a bit closer to the source of the noise.
  6. blackmasked
    London, UK
    I have done a bit of research and others describe it as honking, squeaking even barking ;]
    Have you clicked on the Vocaroo link in my original post?
    #6 blackmasked, Nov 30, 2015
  7. bisco
    49,735
    unfortunately, i don't have flash player on my mac.
  8. goldfinger
    goldfinger Active Member
    535
    402
    Buffalo
    Does it make this sound at different fan speeds? The fan never turns off completely. Try a higher fan speed.
  9. jdenenberg
    jdenenberg EE Professor
    3,860
    1,861
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The clicking is the brake accumulator pump.
    JeffD
  10. bisco
    49,735
    oh boy, that's expensive. i would just ignore it.
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Honks, squeaks, buzzing and barking, rattle-snakes and squirrels?
    Maybe you need an exorcist.
  12. blackmasked
    London, UK
    Thanks for your responses guys.
    I could be wrong but what's in the attached TSB sounds very familiar to the problems I am experiencing.
  13. bisco
    49,735
    that's it!
  14. JC91006
    16,496
    8,406
    You're a bit late for the warranty though
  15. blackmasked
    London, UK
    I got lucky I guess as the car came with 3 month warranty, and the brake actuator a.k.a. brake booster actuator pump assembly has been replaced FOC by the dealership.
