Swapped an engine in on a 2010 that was sitting for 5 months, what else should I do?
Discussion in 'Gen 3 Prius Main Forum' started by suirPPrius123, Mar 22, 2019.
Tags:
  1. suirPPrius123
    suirPPrius123 Junior Member
    22
    Usa
    I bought a 2010 IV with 300k miles that was sirtsit for 5 months for $500, and got a new engine in it for $1500, anything else I should do before I drive it cross country? I've checked tires, brakes, oil change. Thanks!
  2. bettergolf
    bettergolf Active Member
    424
    339
    Sanford NC
    Well, sitting for 5 months may not be good for the hybrid battery either, although mine sat for over 9 months while it was being rebuilt and after 18 months it's performing normally...but it's 5 years newer than yours. I'd give it a chance to work first before spending money on it...it might be just fine.
  3. Leadfoot J. McCoalroller
    7,162
    6,712
    Pennsylvania
    2018 Prius c
    test/charge/replace the 12v battery, add fresh gas to whatever is in the tank, check your other safety items (wiper blades, lights etc)
    Maybe run the air conditioner just to make sure, since it's going to get warm soon at least somewhere on a crosscountry route.
    padroo likes this.
  4. BZzap!
    BZzap! Senior Member
    1,607
    877
    How much have you driven it since the engine replacement? A good shake down would boost you confidence, for sure. Check it over like you would do before an extended trip. Also, if you are competent with your mechanical skill set, just go for it. Good luck on you adventure.
  5. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    What is the mileage on the replacement engine? Was the EGR System ever cleaned?
    The EGR System tends to clogged up as the miles pile up. If not serviced, could lead to head gasket failure.;)
    m.wynn and Raytheeagle like this.
  6. bisco
    49,434
    check the spare pressure and it sounds like you're good to go, have fun!(y)
  7. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    YOLO. Go for it, but buy AAA coverage first.
    Just kidding. Get a couple hundred miles on it at least first. Change the oil again and get it done.
  8. padroo
    padroo Senior Member
    2,763
    2,250
    How old is the 12 V battery? Clean the battery terminals at least.
