Swapped engine last night, now "transmission lock is abnormal??"
Discussion in 'Gen 2 Prius Technical Discussion' started by rogertbp, Apr 9, 2013.
  1. rogertbp
    rogertbp New Member
    Crescent City, CA
    swapped engine last night and now the car won't start and gives me the problem of "transmission lock is abnormal, please park car on a flat surface and apply parking brake."
  2. Mendel Leisk
    40,586
    Well, in the hopes that you don't mind a little levity, and I'm sure more responsible responses are going to be along shortly:
    I wouldn't doubt those two events are related. :LOL:
  3. rogertbp
    rogertbp New Member
    Crescent City, CA
    Hey there Mendel, actually the two are not related. the message is due to low voltage on the 12v battery. I have found not a single post that talks of this error code related to swapping the engine. only low voltage on the battery.
  4. rogertbp
    rogertbp New Member
    Crescent City, CA
    I had the charger on it all night and it still did not bring it up a whole bunch. the battery checked out at 12.88 but varies moment by moment. I am on the way to purchase a new one . when I shut the car off and began disconnecting the inverter and stuff, just for grins I checked the battery, guess what 11.56 volts and I didn't give it much thought until this afternoon. I put the charger on it and brought it back to 12.55 but still not enough.
  5. Mendel Leisk
    40,586
    A just charged 12 volt battery will give falsely high reading. A short drive, or turning on headlights for a couple of minutes (something I can never bring myself to do) is supposed to "burn off the surface charge".
  6. rogertbp
    rogertbp New Member
    Crescent City, CA
    I went down to Orielly and purchased the $241 optima and still no change. off to the dealer to have them get it started. cheaper than a battery maybe. no worries. cheaper than 4500 for them to change the engine that I did in 12 hours with swapping accessories. start to finish.
