Sway bar
Discussion in 'Newbie Forum' started by Dogma, Dec 24, 2012.
  1. Dogma
    Dogma New Member
    I have a 2012 prius v level 5. This is my first hybrid vehicle that I have owned and I must admit that I am enjoying my fuel economy. Since there isn't much one can do to increase power I thought I would increase the handing of the car. I am starting with a suspension upgrade via a larger front sway bar. I have found that tanabe and cusco sell increase diameter bars and I am favoring the tanabe 25.4 mm bar. However, I was wondering if anyone might know what is the diameter of the stock OEM sway bar on the car. Thanks
  2. Johnny C
    Johnny C Member
    162
    16
    Boston
    Planning to get the Tanabe myself or the TRD one that comes on the Prius Performance Plus (or something to that effect).
  3. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Does the v come with a rear sway bar? If not then you should start there. Adding a larger front sway bar will only serve to increase the already abundant understeer.
    sfv41901 likes this.
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    I agree that u should start with a rear sway bar. U might find it to be enough of an improvement.
    I'm happy with my Cusco RSB
  5. DadofHedgehog
    DadofHedgehog Active Member
    681
    281
    northern Virginia
    Try the TRD rear bar - I'm happy with mine.
    Brett Williams likes this.
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    I like the Cusco only cause I doesn't have the brushing that tend to squeak.
  7. Johnny C
    Johnny C Member
    162
    16
    Boston
    Where did you guys get your RSB and how much?
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    #8 sfv41901, Dec 29, 2012
  9. Brett Williams
    Brett Williams Junior Member
    Lake Balboa
    All I did was the sway bar and it works Great.
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    The RSB too me is the best bang for ur buck suspension mod
    iPhone ?
