Sweater, gloves required when driving Volt in cold
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Octane, Mar 6, 2011.
  1. Octane
    Octane Proud Member of 100 MPG Club
    384
    56
    The Swamp, Southern FL
    Sweater, gloves required when driving Volt in cold: Magazine | Wheels.ca
    The result led to the review calling the Chevy EV as “a sweater and gloves commuter car for northern-tier Volt owners.â€
    (You're kidding me. Is GM serious? A $50k car that requires you to wear a sweater and gloves when cold?)
  2. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    ICE's are excellent at generating waste heat unlike EE's.
    Unfortunately, the Volt runs on electricity further than any other hybrid out there.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Yes but EVs have been around for a while and somehow they always seem to get a couple KW heater coil in the dash to warm up the car somehow. ;)
  4. Sho-Bud
    Sho-Bud Member
    190
    Amsterdam, Netherlands
    That's exactly the reason that the Prius plug-in warms up the cabin while it is plugged in.
  5. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    I'm sad to say that as EV has now become real we're seeing some of its drawbacks that before we hadn't thought about.
    I have wondered for months what the numbers look like for a Volt or Leaf in cold weather because batteries hate cold. But then on top of that how much worse they'll be when running the heat.
    I've been slightly changing my mindset recently wondering if ICE-based hybrids are really better than thought. EVs have that incredible battery cost but even after that their cost of operation when compared to an efficient hybrid like the Prius is really not hugely better. Going from 25->50 mpg saves you a lot of money--much, much more than going from 50->100.
  6. Octane
    384
    56
    If the "waste heat" is used to prevent the occupants from getting frostbite, hypothermia, pneumonia, or to keep infants traveling by road alive, then it's hardly waste heat, is it? Further, if it takes a 1.5kW calrod heater which completely drains your battery (exclusive of actually driving the vehicle) just to keep the occupant warm is kind of... well... not thought out very well.
    Actually, it's kind of funny. Take all the power generation and transmission losses, the charging losses, the losses due to battery resistances, the losses at the boost converter and then feed that greatly reduced power into a resistance heater just to keep the occupants warm... LOL.
    As bad as using electricity to heat your home is, it's way worse to use it in an EV to keep the occupants warm.
    This is no small shortcoming of the Volt or any EV for that matter.
  7. Octane
    384
    56
    It may be WAY more efficient to put a little catalytic heater in the car that runs on liquid fuel.
  8. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    I drove a leaf yesterday in 2 degrees for two hours. The heater started off at about 1.5kw use, and once up to a comfy temperature it rolled down to about 800 watts. it seemed to me that it somehow tied heater use to vehicle speed, since pootling round at 30 not much heat appeared, but going up to 60 caused it to start blasting hot air.
  9. Duffer
    Duffer Member
    271
    Perhaps a redesign of the automobile is in order; add more insulation and pay more attention to cabin comfort. If you turn of the heat in any car you can feel the cold almost instantly. It is time to think outside the ICE cage that we have ridden in. These are exciting times indeed.
  10. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    GM-General Menusha
  11. Zhe Wiz
    Zhe Wiz Member
    128
    Ithaca, NY
    Don't you wear them anyway? I do when it's cold, not sure it's THAT big of a problem. Frankly, when I was trying (successfully) to maintain 50+ MPG in the Winter with the Prius, I left the heat off on my 8 mile commute and relied on my coat and gloves.
    This is a common "problem" with all efficient cars, Prius included.
    Zhe Wiz
  12. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    No gloves for me. In fact, 10 minutes into my drive I find myself turning down the heat from it already being too hot. 5 minutes to get out of the city from work (where the Prius sits outside all day) and 5 minutes on the highway is all it takes to get the coolant up to a toasty 193°F. And yes, I do have the lower-grille blocked entirely, but the upper is wide open.
  13. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    I never wear my coat in the car. On really cold days I'll throw it on the back seat on the odd chance that something happens on the road. As stated the Prius warms up nicely very quickly.
    As for the Volt, if there's anything I hate about anything I buy it's finding out after the fact that the things I assumed would work don't. Simple things, you know, like the heater working properly (or the search function for the USB audio input but I'm over that now). Especially when I overpay for an overpriced vehicle. I would be absolutely livid over this.
  14. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Considering it takes 12 minutes to raise 10 degrees, that's the end of one way trip for most.
    Volt will run the gas engine to keep the battery warm but not for the driver and passengers. Interesting design.
  15. Skoorbmax
    2,641
    264
    Western NY
    I agree, it's quite ironic.
    The majority of energy in gasoline is burned off in an ICE as heat and simply thrown away into the atmosphere and yet in this case the system is so efficient that there isn't enough heat so it has to bring some back in.
    That makes sense. Can you give us an idea of how much lower the mileage is when heat is on or off?
    I wear a jacket in a car in winter never, ever, ever gloves.
    I doubt you increased your mileage that much in the 8 miles because by the end your ICE was still at operating temp and shedding heat through the radiator, heat that otherwise could have warmed your cabin.
  16. Skoorbmax
    2,641
    264
    Western NY
    That's pathetic.
  17. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Just remember to always dress for the weather outside, not for the expected weather inside the car/building you are going to. When it is minus whatever outside, and you have no hat and no gloves you are not prepared for an emergency.
  18. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Toyota is taking a cautious approach towards electrifiying cars. If you can't get more than 15k / mo. in US to buy Prius', how you going to get them to buy Leafs which cost more and have much more limitation? Like Reiner (of Toyota) said, the Prius asks no sacrifice of its driver.
    The Leaf is still thee first ever highway capable mass produced EV one can own. We are finding out right now, these days, just how viable it is and will be.
    Volt? Too expensive for what it is. Can't even put 4 adults in it really. 2 adults, 2 children.
    Prius v seems like a smart move if price is right and people like how it drives.
  19. Octane
    384
    56
    It's going to be a tough sell to convince people to go back to living like they were driving a 1960 VW Beetle.
  20. Octane
    384
    56
    Good point, if I were to ride a Yamaha V-Max at 60 mph in the snow, I'd be wearing a helmet, snowmobile suite and gloves.
    The fact that the Volt only seats 4 means there's more cabin space available for the apparel.
