Switching to LEDs - anything to watch out for?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Gouda Cheez, Feb 1, 2014.
  1. Gouda Cheez
    Gouda Cheez Junior Member
    73
    Hello all, I'm considering switching some of my exterior lights (parking lights, turn signals, and a few others) to LED bulbs. Is there anything I should be concerned about before doing so? I know sometimes LED bulbs can cause problems and I wasn't sure if that was the case for the Prius. Thank you in advance!
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    With turn signals, you will get the hyperflashing associated with the low resistance LEDs.
    You can get an LED compatible flasher relay and install it, but it's a PITA to reach the oem relay up and behind the steering wheel.
    sfv41901 likes this.
  3. Gouda Cheez
    73
    This is great - thank you. Any other input is welcome, too.
  4. Gouda Cheez
    73
    With bulbs that run all of the time (ex: parking lights).... is it ok to swap from a regular bulb to an LED?
  5. xliderider
    7,869
    3,116
    Honolulu, HI
    Yes, no problem. Common bulbs converted are parking lights and license plate bulbs.
    SCH-I535
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  7. Gouda Cheez
    73
    Yes. Was actually considering switching the parking lights in the headlight housing to Amber. Saw a few pictures around here and it looked very nice. Another option would be a 'super white' color to match the HIDs I was (eventually) planning to get. Not trying to go too exotic :)
  8. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
    to piggy back on this thread.... has anyone switched to 100% LED inside the cabin? I haven't done a search yet but I will...
    Also I have heard that there are some LED bulbs that have the built in resistance so not to get the "quick flash".
  9. Gouda Cheez
    73
    Thought about doing that as well.
  10. xliderider
    7,869
    3,116
    Honolulu, HI
    Amber, yellow, and 6000K bulbs are common for the parking lights. Stay away from red or blue and you'll be ok.
    SCH-I535
  11. Gouda Cheez
    73
    Thanks. I was thinking amber to match the signals up front and it would provide a nice contrast from the HIDs.
  12. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Watch out for Division 16
    Division 16 — Implements of Husbandry
  13. fuzzy1
    10,149
    Yes, many of us have. I just used vendors that were already convenient to me, without comparing reviews of what others used and reported here. There are very many sources available.
  14. Gouda Cheez
    73
  15. xliderider
    7,869
    3,116
    Honolulu, HI
    Yes, but for parking lights, maybe not so much. Reason is, parking light bulbs point straight up, those bulbs you linked send most of the light forward. You might want a bulb with some SMD LEDs mounted on the sides for your parking lights.
    SCH-I535
  16. Gouda Cheez
    73
  17. Gouda Cheez
    73
  18. fuzzy1
    10,149
    I have changed only the interior lights, partly to reduce the risk of a dead 12V battery if something accidentally gets left on. I've done it before on past cars, a friend with a recent new car (not a Prius) was plagued with this issue the entire first week of ownership.
    Your link above is similar to an older style I used for the map and vanity lights. For the door puddle lights, and trunk light in another car, I used something similar to this: 194 LED Bulb - 6 SMD LED Wedge Base DAC
  19. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
  20. Gouda Cheez
    73
    I've thought about that as well. Looks good. Could always go with the 168/194 ambers in there as well if I wanted to go that route.
