Switching to Synthetic Oil
Discussion in 'Gen 2 Prius Main Forum' started by ghopper01, Jul 17, 2007.
  1. ghopper01
    ghopper01 New Member
    From what I read on the forums, looks like there’s lots of benefits to going to synthetic oil (going to use Mobil 1 5w30). I have a few questions:
    [1] Are there any special steps that need to be taken to switch from factory oil to synthetic (first oil change approaching)?
    [2] Will most dealers have synthetics, or will I need to purchase and request that they use it?
    [3] Any impact on warranty or servicing?
    [4] Should I stash an extra quart in the truck, just in case?
    Thanks
  2. jamarimutt
    jamarimutt New Member
    985
    <div class='quotetop'>QUOTE(Grasshopper 01 @ Jul 17 2007, 09:05 PM) [snapback]480609[/snapback]</div>
    Could you provide evidence that synthetic oil is better for the Prius than regular oil?
  3. ghopper01
    <div class='quotetop'>QUOTE(jamarimutt @ Jul 17 2007, 09:11 PM) [snapback]480615[/snapback]</div>
    Search the site (keyword: synthetic) and you'll find several threads on the topic. Also, several sites available from a Google or Live search.
  4. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    1] No special steps. It's like any other oil drain.
    2] Depends on your dealer. Many will have it. If you bring your own, they may or may not use it, depending on their honesty.
    3] No
    4] No
    Why have the dealer do it? The warranty doesn't require it. Take it to a reliable shop (not a quickie joint!) for less money, or do it yourself for even less
  5. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Yes
    lenjack's answers are good. Two additional comments:
    I don't see the advantage of stashing an extra quart in the truck :D either, but I have found that an extra quart in the trunk came in handy one time when the oil filter was not put on tight enough initially.
    It's usually automatic, but get the oil filter changed as well since it will hold quite a bit of the old oil if not changed.
  6. Swanny1172
    Swanny1172 New Member
    666
    What's the matter, is Google broken?
