Switching wheels from 15x5 to 15x6
Discussion in 'Prius c Main Forum' started by CARSFAN4, Sep 15, 2024.
  1. CARSFAN4
    CARSFAN4 Junior Member
    62
    Los Angeles
    2015 Prius c
    I got already 2 bent steel rims and decided to switch to wider steel ones to compensate for turns instability on Freeway at 70mi/hr. My regular wheels are 15x5 with tires 175/65/15.
    If I buy 15x6 wider rims what size of fitting tires I need??
    I also need to know what length should the new wheels screws should be ???
    Thank you!!!
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    The stud lengths wouldn't be need to be changed, it's the offset or backspacing of the wheels you need to be mindful of.
    Also, how are you getting bent wheels, unless you are hitting potholes or something?
    SM-G781V ?
    CARSFAN4 likes this.
  3. xliderider
    8,140
    3,277
    Honolulu, HI
    Also, if you want the tires to be more responsive during cornering, you want lower profile sidewalls, that would have less flex during cornering than taller profile sidewalls.
    For that you would need to get larger diameter wheels and tires like 17 inch wheels and tires with the same overall outside circumference as your oem tires so your speedometer and odometer are accurate.
    SM-G781V ?
  4. Mendel Leisk
    42,232
    Slow down a bit, especially with speed bumps, sunken manholes and the like. And sleep on the tire change?
  5. BiomedO1
    BiomedO1 Senior Member
    4,480
    2,355
    Left Coast
    FWIW, I've never been able to bend a steel rim. Scuffed them up and popped tires running them into curbs - but never bent them to a point that they don't balance or hold air. I've even put a dent on the tire bead, once - pounded it out with a hammer, replaced the tire, and balanced.
    Here's the data you requested.
    2015 Toyota Prius c - Wheel & Tire Sizes, PCD, Offset and Rims specs | Wheel-Size.com
  6. Leadfoot J. McCoalroller
    8,261
    7,763
    Pennsylvania
    2018 Prius c
    Oh, my wife found a way to bend a steel rim. I asked around about a wheel shop to get it trued later, but (at least in my area) that apparently went out of fashion in the 70s, everyone said "just buy a new wheel, they're cheap."
    I guess I would not think of "wider tires" as the go-to move for "turns instability" issue in a Prius c.
    ...I'm not saying I know of a magic fix either.
    If anything I'm curious about what exactly "turns instability" means.
    I've driven many miles in Los Angeles, but never in our Prius c- and I'm not sure I'd want to. All those expansion joints on LA freeways are uncomfortable in medium-wheelbase cars, and probably even less fun in a short-wheelbase car like a c.
  7. CARSFAN4
    62
    Los Angeles
    2015 Prius c
    Yes, I wrote above at the beginning of one of the threads that I hit a curb because of lack of lights on the road.
    Can u elaborate in detail how to check the offset and backspacing. I never did that before. Thanks
  8. CARSFAN4
    62
    Los Angeles
    2015 Prius c
    That's exactly why the short wheel base and the narrow car width makes it difficult to make a sharp turn at 75mph on the freeway: i.e. Fwy 110 N. to Pasadena from DTLA, CA.
