Swop radio
Discussion in 'Gen 3 Prius Audio and Electronics' started by Tonio, Aug 8, 2017.
  1. Tonio
    Tonio Junior Member
    Dublin, Ireland
    Hi
    Can I replace my basic Prius radio/cd with the touch version?
    Will everything work the same?
    Cheers
  2. Tonio
    Tonio Junior Member
    Dublin, Ireland
    It looks like I can't...the touch is for the 2012 on
  3. FrankB
    FrankB Member
    117
    53
    I swapped mine. It requires an antenna adapter and one wiring harness change as far as I recall. It's a worthwhile upgrade. If you add the USB cable, you can connect an iPod or use a USB stick. Also, bluetooth streaming is nice except you would have to add a microphone to get phone functionality. I can only stream audio from my phone over bluetooth, not take phone calls.
  4. ChapmanF
    15,478
    How does the bezel color match your 2010 dash?
    -Chap
  5. FrankB
    FrankB Member
    117
    53
    It doesn't. But I really like the additional functionality. Most aftermarket units wouldn't match either.
  6. 5isalive
    5isalive Junior Member
    So I did this swap with the 57032 to get the HD radio but Bluetooth won't work. Any ideas?
    iPad ?
  7. FrankB
    FrankB Member
    117
    53
    I don't think there are any bluetooth connections on the wiring harness.
  8. 5isalive
    I know there would be connections for the microphone but what is needed for the Bluetooth streaming?
    iPad ?
  9. FrankB
    FrankB Member
    117
    53
    Nothing that I can think of, it just worked for me.
    SM-T550 ?
  10. DPEXP
    DPEXP New Member
    florida
    Are you able to get audio from the USB input ? Im curious to know if the USB and the bluetooth streaming are both inoperative.
  11. 5isalive
    Ok finally got the USB cable and took the radio out again to hook it up. It seems the bluetooth part is a separate box with what looks like a single maybe fiber connection to the main radio. It is made by harman kardon I believe it was marked and has a 32 pin connector on it with the grey usb connector also. The main radio also had the grey connector and was working there but of course not off the separate box. Need to find something to hook to that thing so I can get bluetooth.
  12. 5isalive
  13. 5isalive
    Another update. Got the cable installed and have entune and it kind of sucks. Upgraded it to newest version 5.2. Bluetooth now works and waiting on antenna for gps. Doing research on what it will take to put in reverse camera.
    iPad ?
