Symptoms of dying auxiliary battery? Puzzled.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by productofdesign, Aug 1, 2016.
  1. productofdesign
    productofdesign New Member
    Grove City, PA
    Hi all,
    Symptoms:
    1) A month ago, our key fob began to sporadically not unlock the car remotely. It got worse and worse (resorting to manually unlocking the car w/ the metal key), then after a while, it also stopped locking the car remotely, altogether. Both functions lost now.
    2) Around that time, there was an episode where the car would not start with the key fob in the slot or remotely. Then when it finally did after many attempts, it would not shut off using the Power button. I pushed the 'Key' button in (located under the steering wheel), and now it start up/shuts off normally for the past several weeks, no problems.
    3) I replaced the key fob battery, but the remote access issues still persist. The small red light on the fob lights up when I press the lock/unlock buttons near the car, but to no effect.
    4) This past week, my wife was pulled over since the driver's side brake light was dim. We noticed this before but it was intermittent. All the LED lights are together dim or bright as the other, but it's off and on.
    5) The dome light above the back seats was stuck on last week. We've had to remove the lightbulb to temporarily resolve it.
    6) The clock doesn't light up at all and stereo system are dead now (whether car is running or not). The 'Add Fuel' warning nearly always is flashing. When you start driving, the Consumption miles is always back to '0 miles'.
    7) The car-door unlock/lock button won't work properly unless the car is turned on.
    8) In ACC mode using the multi-screen display, the auxiliary battery voltage is 11.9V, which seems borderline. Using a voltmeter, I manually read a voltage of 12.6V with the red/black terminals still connected to the car, which was off.
    Background:
    - 2005 Prius,
    - bought used a year ago May,
    - No idea when auxiliary battery was installed.
    Dx:
    If it was a dying auxiliary battery, wouldn't driving around charge it up and resolve these issues?
    Just hoping it's not an more intricate electronics issue ...
    Thanks!
    David
  2. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    How many miles on the car? It certainly sounds like it could be battery related and 11.9 in ACC is low. I know many auto parts stores like Auto-Zone will do a free battery test that would be worth doing (though they're super sensitive and often call batteries "bad" a few years before they need to be replaced). They usually give you the results which you can compare to the expected performance new though.
  3. productofdesign
    Grove City, PA
    Thanks Kevin, there's 160k miles on the car.
    Are ordinary voltmeters not sufficient, or they have the specs on what the voltage should read for each model of battery? What is the expected new voltage?
  4. Kevin_Denver
    581
    425
    Denver, CO
    A simple voltage test is not sufficient to determine the health or capacity of a battery. It needs a load test, which determines the voltage under load.
  5. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    You reported the voltage in ACC mode. What are the voltages in IG-ON (more load--turn on A/C fan and headlights) and "Ready" modes?
  6. bisco
    51,155
    what is the stone cold voltage, after the car has been off for at least 4 hours, and how old is the 12v battery?
  7. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Dx:
    Driving around isn't going to recharge the battery. It needs to be on a trickle charger but it sounds like the battery is at the end of its useful life.
  8. productofdesign
    Grove City, PA
    Hi all,
    So I put down $150 on Amazon for Optima Batteries 8171-767 (DS46B24R) YellowTop Prius Battery and replaced the battery this evening ...
    Issues persist - unfortunately, none of the above symptoms are resolved.
    Any further ideas on this one?
    The $80-90 to have Toyota look at it is becoming more of a possibility, as difficult as it is for my DIY brain to think it.
    Thanks,
    David
  9. bisco
    51,155
    was the negative to body connection tight and clean?
  10. productofdesign
    Grove City, PA
    Yes, no corrosion or loose connections.
    A couple days ago, I took the old battery (within Prius) to AutoZone to be tested. They left the battery in the car while performing the load test, and indicated the battery was bad.
    I should note that the MAINT REQUIRED light is on solid. But it's about time when I replace the oil filter.
    #10 productofdesign, Aug 4, 2016
  11. bisco
    51,155
    sounds like you have gremlins, maybe time to trade her for a younger model.
  12. productofdesign
    Grove City, PA
    VICTORY! Haha!
    I started Googling on just the clock/stereo dead issue, and found another person solving their problem on a Corolla by replacing a fuse.
    So I found the 2005 Prius fuse label, and located the fuse which best describes my problems (location 39, a 15A fuse): Radio fuse or fuse diagram | PriusChat
    39. DOME 15 A:
    Audio system, interior
    lights, smart entry and start system,
    gauge and meter, turn signal lights,
    luggage room light, clock
    I replaced it with the spare 15A fuse located at position 24, and Whala! Key fob, clock, stereo, dome light all work!
    The original fuse is severed for sure, per the photo.
    So glad this is resolved. And now a new battery to boot, what's more.
    Thanks all!
  13. Patrick Wong
    18,200
    6,493
    Your OP says the dome light was receiving power.
    This post implies the dome light was not receiving power if the DOME fuse was blown. Apparently something happened between the time you observed #5 in your OP and your latest post.
  14. productofdesign
    Grove City, PA
    Patrick,
    The dome issue description was relayed to me through my wife, and something must have been lost in translation. It wasn't verified as other issues which were conducive to quickly confirm.
    When I replaced the fuse the dome light fired up instantly suggesting that, on the contrary, the dome light was out cold until the circuit was operational again.
    My approach is that some diagnostic cases reveal some issues as red-herrings which appear to contradict the eventual logic of the fix.
    To bear through the cognitive dissonance, apply Occam's Razor and explore all the possible fixes for the most issues helped in this case?
    I worked at a small engine repair shop for a few summers - it became apparent that some engines had everything in place but could not fire up at all, while others, which didn't seem to have a chance, which did. Very frustrating at times.
    Experiencing it all without omniscience, I've relinquished it to both a science and an 'art'?
    Thanks for reading my soliloquy,
    David
