Syncing Droid Razr Maxx contacts with 2010 Prius V
Discussion in 'Prius v Audio and Electronics' started by dmcneill, Mar 23, 2012.
  1. dmcneill
    dmcneill New Member
    Nebraska
    Has anyone successfully transferred telephone contacts from a Verizon Droid Razr Maxx to a 2010 Prius V? If so, directions and guidance would be most appreciated! Thank you.:)
  2. shoedad
    shoedad New Member
    Rapid City, SD
    I just did my 2007 tonight but not sure it's the same as your 2010 but here is what I did.
    First download the app Bluetooth File Transfer (free) from the marketplace or google play as it is now called.
    Go into your contacts and save them to your SD card it should save as a .vcf file (mine was 00001.vcf) ...notice where it is saving it mine was /mnt/sdcard-ext
    Go into your radio phonebook and start the trasfer process for phonebook
    Go back to your droid and open the Bluetooth File Transfer app then go to the location where you saved the file....click on it (check box button) then hit the menu key and select SHARE (mine was under the More menu item)....I couldn't get the send via bluetooth to work so you must have to use share
    It should transfer at that point.
    Hope that helps a little
