T-SB-0047-09 IG1 Relay Freezing
Discussion in 'Toyota Prius Service Bulletins - TSBs' started by Patrick Wong, Jan 13, 2010.
  1. Patrick Wong
    18,210
    6,517
    Alaskans, Canadians, and northern 48 state US owners that face sub-freezing weather, take note.
    2006-2009 Prius: IG1 relay may freeze up when temperature drops below 14 degrees F (-10 degrees C). The symptoms are that multiple warning lights will appear and the car will not shift from P to D. Accessories may not work.
    The solution is to install a new IG1 relay, which has a different part number.
    7 people like this.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Good info...
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    The replacement part retails $65. I am way beyond 36 months / 36k miles coverage.
    I have never gotten multiple warning light nor an issue with shifting from P to D. However, I was unable to press radio related buttons. Even the radio power button did not work. I was able to operate from the steering wheel buttons. After a couple of miles they were all fine.
    I have experience this only once and never since then.
  4. Patrick Wong
    18,210
    6,517
    If the problem returned, a short-term solution might be to strike the instrument panel above your left knee (when sitting in the driver's seat) - maybe that will jog IG1 into working! :D
  5. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    Open the fuse box and hold IG1 with your fingers to warm it up. That should do the trick.
  6. Flying White Dutchman
    4,376
    313
  7. dogfriend
    7,512
    1,191
    Carmichael, CA
    Or move to a warmer climate. :madgrin:
