Tach for Prius C ?
Discussion in 'Prius c Accessories and Modifications' started by mahout, Mar 29, 2013.
  1. TRD
    0 vote(s)
    0.0%
  2. EME
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. mahout
    mahout Active Member
    655
    116
    NC
    Anyone know of a source for tachometer for the Prius ? Yes, I know it won't be much use but I'm so used to driving by tach.
  2. nklb
    nklb Member
    111
  3. Mendel Leisk
    38,751
    ScanGaugeII shows 4 OBD values at a time, including RPM. I'm using it, pretty much always showing RPM, Coolant Temperature, Instant MPG and Accumulating MPG since last start up.
    nickjans3 likes this.
  4. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Moved to the Prius c forums from the Prius v forums.
  5. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    And yes I use RPMs as one of my Scangauge II gauges, if nothing else it is interesting to see that RPMs relates to MPG
  6. KaliforniaKid
    KaliforniaKid 2013 Prius v Five 2012 Priuc c Four
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    I went with the lower priced but larger display UltraGauge.
    All I simply wanted was Tach, outside temperature, coolant temperature and charging voltage displayed.
    UltraGauge does it while looking good on the eyes and in the car.
  7. Mendel Leisk
    38,751
    ^ I find Coolant Temp very handy. The Prius have a suprising absence of gauges. Maybe a blessing? If you care you get add-on gauges that are more accurate/imformative than the rudimentary built-ins.
  8. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    I run the torque app on my android phone running through a $15 bluetooth obd2 adapter. Works great.
