tail and brake lights out on both sides
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by noctiluca, Sep 4, 2017.
  1. noctiluca
    noctiluca Junior Member
    40
    Vancouver, BC
    2014 Prius v wagon
    Hi all, the brake and tail lights are out on my car. The bulbs (that I think are shared between tail and brakes?) are blown out on both sides, tail fuse is okay, and no power is getting to either of the sockets. I also have an intermittent driver side headlight go out that works again when whacked. Is there any wiring implicated in all of these symptoms? The turning signal, reverse lights and license plate lights all work.
    If anyone could suggest an order of operations for finding the problem that would be really helpful, I have a hard time reading wiring diagrams but can do basic electronics stuff like testing, cleaning contacts, soldering, etc.
    Thank you!
  2. JC91006
    16,673
    8,518
    If all the lights work, other than brakes, you'll probably need new ones. Those LED lights are not self replaceable
    What year is your car?
  3. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    brake light switch behind the brake pedal would be my guess if you have good bulbs and fuses..or a common ground is bad..
  4. noctiluca
    40
    Vancouver, BC
    2014 Prius v wagon
    are the (running) tail lights and brake lights the same bulb? the bulbs i pulled out, presumably the tail lights, don't look like LEDs and have burnt out filaments. the bulbs are dead and the sockets are dead.
    the car is a 2005. anyway to tell if the brake light switch is busted other than putting a new one in?
  5. JC91006
    16,673
    8,518
    It's your brake LED lights that are bad, they are not individual units you can replace, the bulbs you pulled out are reverse or turn signal bulbs
  6. Beachbummm
    1,160
    392
    remove the switch and test it with an ohm meter.. watch a youtube video on how to test switches.
  7. Patrick Wong
    18,200
    6,493
    The tail light is an incandescent bulb and the brake light is six LEDs.
    Use an ohmmeter to test the operation of a switch.
    Paul Schenck likes this.
  8. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    I got my replacement Bulbs at Walmart, and they came in a package with a push button test with battery. Start with a good bulb and testing the switch may get easier!
    iPhone ?
  9. Peter Fanelli
    Peter Fanelli Junior Member
    36
    Smyrna, Tennessee
    I was informed by a police officer that I had a brake light out a while back. When I checked it they were both working but that seems to be the way with Prius LED brake lights. It's too expensive to keep replacing the whole unit so I modified mine to use replaceable LED bulbs.
    I turned the reversing lights into brake lights with a red LED bulb and I replaced the turn signal bulbs with amber/white switchback DRL LED bulbs.So the turn signals do double duty as turn/reverse lights. Only disadvantage is that if you select reverse with the turn signal on you do not get white light on that side. Minor problem really.
