Tail light lenses hold water
Discussion in 'Prius c Main Forum' started by Chevelle Todd, Aug 31, 2020.
  1. Chevelle Todd
    Chevelle Todd New Member
    Orlando
    Does anyone else on here have issues with the tail light lenses holding water.
  2. David9962000
    David9962000 Member
    141
    68
    2020 Prius
    I would replace it with a used one before the water/humidity causes electrical problems. It probably has a bad seal. You can find a used one online.
  3. RRxing
    RRxing Senior Member
    2,548
    1,825
    NEPA
    Both lenses?
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,474
    2,440
    Taylors, SC
    A simple quick temporary fix would be to drill a quarter inch hole at the bottom to drain the water. Take out the bulbs and coat the contacts with dielectric grease to prevent corrosion in the contacts.
    After the unit dries, try to find the water entry point and seal it. If found, seal the drain hole. too,
    Works and a lot cheaper than replacement.
    Lukey51 likes this.
