Tail lights leaking in my new 2019 Prius LE :(
Discussion in 'Gen 4 Prius Main Forum' started by Chris Wolfgram, Dec 9, 2019.
  1. Chris Wolfgram
    Chris Wolfgram Active Member
    411
    167
    Sacramento CA
    2019 Prius
    And here's the kind of crappy part... I had bought super bright LED backup bulbs, but had not installed those yet. Of course if I had, they would say, I made the lights leak from messing with them. If they fix them, and I put them in after, and they leak again, they will still say it was my fault.
    I'm wondering, if I told them the lights were leaking (or just let them see the lights when they had moisture inside) and they had to either seal them better, or replace them anyway, if I could just say, BTW, would you mind throwing these in since your going to have them open anyway ?
    My buddy used these same LED back up lights in his 2019 Prius LE, and they are ridiculous bright ! Makes the backup camera much easier to see at night...
    How common is it for the tail lights on a brand new Prius to leak ???
  2. krmcg
    2,592
    2,388
    Whittier, CA
    Light condensation or standing water?
  3. alanclarkeau
    alanclarkeau Senior Member
    7,041
    7,580
    near Brisbane, Australia
    I'm certain that the dealer wouldn't install non-genuine lamps.
    Are they legal? Last thing the authorities want is for everyone with super-bright reversing lights - TOYOTA would have gone through ensuring the originals are compliant - and the dealer wouldn't risk installing them.
  4. Chris Wolfgram
    411
    167
    Sacramento CA
    2019 Prius
    Condensation inside of the clear backup light portion....
    krmcg likes this.
  5. Chris Wolfgram
    411
    167
    Sacramento CA
    2019 Prius
    Honestly, I couldn't give a chit less.... I mean, I only use my backup lights in parking lots and such anyway. Almost never on a public roadway. But like other things guys have brought up here, maybe you live in an area where cops don't have anything better to do, but mess with you for stupid little stuff like this. But here in Sac, you would have a hard time finding a cop to pull you over for going 60mph in a 40mph zone. They are just overwhelmed around these parts with hard core crime. No time for small stuff.
  6. srbinoki
    srbinoki Junior Member
    29
    Boston, MA
    Four Touring
    Condensation is normal since that part of the light assembly is not sealed. If it was sealed you wouldn’t be able put in your ridiculously bright LEDs.
    krmcg likes this.
  7. Leadfoot J. McCoalroller
    6,824
    6,473
    Pennsylvania
    2018 Prius c
    Condensation is generally no big deal, it's going to happen anyway with normal weather. A few minutes in sunlight clears them out.
    Filing up with rainwater is not normal though. That would be a threshold for action by a dealer.
  8. Chris Wolfgram
    411
    167
    Sacramento CA
    2019 Prius
    Really ?!?! That sounds completely wrong to me. I've never seen any head or tail light assembly that was not completely sealed ? But if you say so....
    I'm still going to mention this to the dealer, and see if they think its an issue. Hmmm...
  9. Leadfoot J. McCoalroller
    6,824
    6,473
    Pennsylvania
    2018 Prius c
    How much of a seal do you need? There's safeguarding human life in Earth orbit and there's keeping horny spiders out. Toyota taillights are closer to the latter. Moist air can get in, then the assembly can get cold and boom you've got condensation.
  10. Chris Wolfgram
    411
    167
    Sacramento CA
    2019 Prius
    I don't know. I've had a bunch of vehicles, including 5 brand new ones, and never had a new one leak.... Or even get condensation in it. I'll definitely mention it to Toyota though. And I'll try to bring it straight in the next time I see moisture inside of the light...
    alanclarkeau likes this.
  11. ETC(SS)
    6,493
    Pictures......or it never happened.
    I'm thinking that if I'm Toyota I'm going to slow-roll you on the reverse lights.
    I mean, yeah.....they'll pretend to care....maybe....if they think you're going to buy another car from them..... but at the end of the day the backup lights will still illuminate when you put the little joystick thingy in "R" and if there's a little condensation in the rear lamp assembly then it's not likely to detract from the....ah......."beauty" of the car.
    After all.....I get condensation on the windshield all the time but I'm not expecting the dealer to install a new windshield.
    If I were you I'd install the illegal backup lights and maybe also put in a desiccant pack if it's possible to do so in the space provided because you're already planning on hacking the lamp assembly anyway.
    Then?
    Relax and try to enjoy the car.
    Good Luck!
  12. Leadfoot J. McCoalroller
    6,824
    6,473
    Pennsylvania
    2018 Prius c
    I don't want to sound unsympathetic- I realize it's less than ideal to see any water in there. But it also doesn't sound like it's anything beyond nuisance-level.
    I don't see this leading to a dealer removing or opening the taillight assemblies, so it isn't a way for you to skip the effort of putting in your new bulbs. If you take it in, they'll have the shop idiot point a hair dryer at it for 10 minutes, and chances are it'll work, no disassembly required.
  13. ETC(SS)
    6,493
    He could roll the dice and hope that their "ace mechanic" melts the plastic.... :p
    I'd be interesting to hear if the dealer finds out anything else that "needs fixing" while the car is in for repairs..... :D
  14. Leadfoot J. McCoalroller
    6,824
    6,473
    Pennsylvania
    2018 Prius c
    One of the very few problems we've had with our Hyundai Accent was water intrusion into the 3rd brake lamp assembly, causing electrical failure.
    When I got the replacement unit, I applied some tracks of MEK along the accessible seams of the thing to fuse the plastic together.
    It has now gone more than 2x as long as the original. No way to know if it was their work or mine that made it last, but I'm happy with the overall result.
  15. alanclarkeau
    7,041
    7,580
    It's 25 years since I had condensation in a light on a newish car - yes, on some old cars or back in the days when they didn't make them very carefully.
    I'd be taking it back to get fixed.
