Tail (stop) light replacement part # or clues.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BiteyKitty, Aug 26, 2019.
  1. BiteyKitty
    BiteyKitty Junior Member
    Monterey, CA
    My 2005 (according to the cop who stopped me) has the rear driver's side break light out. I think Google alleges it is an LED but i am not able to locate an obvious replacement on the usual sites. Any vendors stick out? Maybe a part #? Thanks!!
  2. Patrick Wong
    18,200
    6,474
    81561-47071, MSRP $206.82, $139.26 from AutoNation Toyota Gulf Freeway in Houston:
    Combination Lamps for 2005 Toyota Prius | AutoNation Toyota Gulf Freeway
    If the BRAKE light(s) are out, they are LEDs and it is necessary to replace the entire taillight housing.
    I suggest you back up into a space that has a glass window or other reflective surface to act as a mirror, so you can see via your rear mirror exactly what has failed before you buy a replacement.
  3. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Or have someone press the brake petal while you look. That would work also.
