Tailgate won't open
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hamptgx, Dec 29, 2018.
  1. Hamptgx
    Hamptgx Member
    66
    27
    Northern Illinois
    Tailgate switch won't unlatch rear hatch. It's new (2 weeks installed), aux battery is 3 weeks old and fully charged. Just finished putting new struts on front and rear. Replaced pass side tailight, near as I can see all power leads connected, can feel gate switch move when depressed, it's like the mechanism isn't getting power, is there a fuse feeding this? Any pointers would be appreciated.
    ADMINISTRATOR PLS DELETE THIS THREAD - FIGURED IT OUT.
    #1 Hamptgx, Dec 29, 2018
    49,371
    does the fob work and car start?
    crawl in through the back and see if the interior release works. take a flashlight and o/m.
  3. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    Will it unlock the other doors. If so the actuators probably just not moving needs to be glued or the motor needs to be cleaned inside or replace
  4. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    I think I had to remove cover and used a ice pick to push the latch open then push up all at the same time two man job easier. If there's a latch let me know
  5. bisco
    49,371
    will doo
  6. Hamptgx
    Hamptgx Member
    66
    27
    Northern Illinois
    Yep, something had to be loose, once I took everything out and checked all connections it started working again. Go figure?
  7. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    Do you have a water leak may have corrosion in the connector fall The wire to the side of the hatch the a connector if you have a leak it'll probably be green when you take it apart
