Tailight short 2nd gen
Discussion in 'Gen 2 Prius Main Forum' started by James1964, Aug 17, 2018.
  1. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    2005 prius brake lights stopped working. Is this a short? Is the fix to replace the entire assembly?
  2. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    Both sides or just one?
  3. PriusCamper
    PriusCamper Senior Member
    13,071
    5,306
    Pacific Northwest, USA
    If it's just one, it take two minutes to replace the bulb... If it's both of them it takes 3 minutes to replace the fuse...
  4. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    Ummm, the brake light is an LED cluster, and the official repair is to replace the whole light assembly, as the brake lights are not designed to be user replaced.
    It is possible to crack open the assembly and replace the LEDs with new ones, if you have a lot of time and are good with a soldering iron and electronics in general.
  5. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
    Let's start with the easy stuff--check fuse and then brake pedal switch.
    Skibob and fuzzy1 like this.
  6. PriusCamper
    13,071
    5,306
    This is an '05 Prius with mostly light bulbs and OP hasn't even yet indicated if problem is all brake lights or just one? As for official repair... Well, never mind...
  7. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    Thanks everyone! Sorry I disappeared this thread. I ended up replacing the entire tailight assembly. Working well.
  8. MichaelKnight
    MichaelKnight Junior Member
    39
    22
    Westcoast
    Glad you replied back with an update James. Glad you were able to square this away.
    Which assembly did you end up with?
    1.New oem (online,@dealer)
    2.Aftermarket (brand,link,quality) please update in future if possible....
    3.Did you replace just one assembly or both? (driver side or passenger)
    @James1964 did you ever update your other post regarding the clazzio? If this wasn't you disregard.....
    James1964 likes this.
  9. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    I'll do my best Michael:
    Replaced only the affected tailight assembly.
    Bought off Ebay. Chinese made I'm pretty positive. I'll check for the make but it was definitely a lesser quality than OEM. Yes, that was us who did the complete, synthetic leather Clazzio make over! A bear of a job but so worth it. I recently stitched on the leather steering wheel cover too. Wheelskins? Think that's the brand. I recommend that too.
    MichaelKnight likes this.
  10. MichaelKnight
    39
    22
    Westcoast
    Thanks James
    Hope it didn't feel like 21 question lol
    I am currently currently looking into both the clazzio and now the steering wheel cover too!! Thanks for recommending both products...
