Taillight fit help?
Discussion in 'Prius c Accessories and Modifications' started by theblueprius, Aug 14, 2019.
  1. theblueprius
    theblueprius New Member
    Flagstaff
    So I got some valenti taillights off eBay, and they are supposed to fit my 2012 C but the electrical is all different on it. , my gf took a picture of the back for me, my oem lights have multiple cords and the new one only had the one attachment. Anyway to retro fit? Or am I screwed?
  2. Leadfoot J. McCoalroller
    8,103
    7,587
    Pennsylvania
    2018 Prius c
    You can always chop the connectors off both car and lamphousing and make splices instead. It's not like they changed voltage or the number of lamps or anything.
  3. frenzee
    frenzee Member
    95
    73
    16
    Costa Mesa, CA
    The OEM taillight has a harness with one connector at one end and 4 at the other for the brake, driving, reverse and signal lights. It looks like the intention of this particular manufacturer was to circumvent the harness and go directly from the light assembly to the single main connector.
    That connector is inside the C-pillar, towards the center, behind the sheet metal.
    You will need to first unplug the OEM light assembly, dislodge that large, round rubber seal which passes the harness through the sheet metal, then open the plastic panel on the inside of the C-pillar to get to the connector to unplug it. You won't be able to see that connector. You'll just have to work by feel. You will also need to take out the center plastic cover above the spare tire in order to take the C-pillar cover off. The cover is held in place entirely or mostly by clips, but I think there is at least one bolt/screw. You don't have to remove the whole thing. You just need to open up a gap large enough to be able to reach the connector from the other side and unplug it. Installation steps are the same in reverse order.
    It's a very simple process, but wear mechanic's gloves and a long-sleeve shirt to save your knuckles and wrists, because the plastic parts are sharp.
    I think I posted some pictures on this topic about a year ago, but I can't find it now.
