Taillights out
Discussion in 'Gen 2 Prius Main Forum' started by splashback, Jan 25, 2008.
  1. splashback
    splashback New Member
    26
    chicago
    a week or so ago my wife noticed that both tailights were out. I looked at the fuses and everything seemed fine. I then banged in each light with my fist- they turned on!
    Now every once in a while my left tail light is out- I just have to hit it to turn it on.
    Any suggestions?
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    It could be the bulbs. Try replacing them.
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    it's the harness. when you see prii running around on the streets you'll notice the rear right one goes out first... i messed around with my clip enough where mine usually doesn't go out anymore.
    i've seen the passenger light go out.. or "short out".. or lack of connection i guess... anyways.. it goes out first, it seems.
    open the hatch, pull the plastic covers off, and fiddle with the harnesses.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    For the driver's side, open that cover to get the jack and you'll be able to access wires for taillight. Try to move them around. That should be better than banging.
  5. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    +1 on the wiring harness. Simple to fix, but a PITA to get too sometimes. If your prius is still within the factory warranty, take it back to your delearship and document the problem. Good Luck.
  6. Skwyre7
    Skwyre7 What's the catch?
    2,332
    Richmond, Virginia
    I've got the same problem with my driver's side tail light. Last year the brake light wasn't working due to a faulty LED. Fixed for about $35. Now, the same light is having taillight issues, similar to those mentioned in the original post. I haven't had time to fiddle around with it yet. I've gotten a lot of people to tell me the light is out though.
  7. Skwyre7
    2,332
    Richmond, Virginia
    I finally got a chance to wiggle the tail light wiring harness. As soon as I touched it, the light came on. It's still on. :D
