"Take a rest" notification
Discussion in 'Prime Main Forum (2017-2022)' started by gohanvox, Jan 29, 2017.
  1. gohanvox
    gohanvox Junior Member
    Burbank, CA
    Was driving at, admittedly, higher than the limit speeds, when I got a signal indicator to "take a rest". Does that mean slow down or...?
    iPhone ?
  2. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    I thought it keep track of your LDA and if it seems like your swerving more than you were for a bit of time, it will suggest that
    jmarkd7 likes this.
  3. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    I tend to stay on the right side of the lane and the car tells me to rest, often, so I tend to turn off the lane departure warning device;)
    jmarkd7 likes this.
  4. mr88cet
    mr88cet Senior Member
    2,306
    1,331
    Austin, TX
    In the YouTube videos, I remember seeing a coffee-cup icon to tell you that you're weaving. I don't remember them mentioning any word message associated with that.
    Anyway: Display asks if I would like to rest | PriusChat
  5. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Is this with your '12 model C ??
    I didn't think that the C had the electronics to do that, at least not back then.
    My C-3 certainly does NOT.
    No doubt it is the "lane departure" feature that's doing it.
    It "thinks" that you are turning the wheel too often.........or not often enough (as is starting to doze off).
  6. bwilson4web
    15,513
    I suspect there is a clock involved too.
    Kramah313 likes this.
  7. huskers
    huskers Senior Member
    2,543
    2,486
    Nebraska
    Can you just say, "no" to it?
  8. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    For me, 100% of the time it happens when I am in a curvy road or I don't bother to signal when I change lanes. Bad habit and all.
    jmarkd7 likes this.
  9. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    It is a result of the Lane Swaying tracking. You can find that setting under Vehicle Settings on the Multi-Info Display on the dashboard.
    You can turn it Off/On. By default it is Enabled. If you are constantly swaying from left to right and back and forth, as alerted by Lane Departure Alert, it will be triggered. It is not speed dependent.
    It is a separate setting you can control aside from LDA but I don't know if it depends on the LDA for this warning or it is always monitoring the swaying movements. I am guess it is tied to LDA. If you turn off LDA from the steering wheel (next to the cruise control distance setting) or the vehicle settings, I am guessing it probably will not trigger swaying alert.
    I guess I will have to test it a bit and see if I can reproduce it again and record another video. :)
  10. gohanvox
    Burbank, CA
    Thanks, all!
    iPhone ?
  11. Trollbait
    11,513
    Won't Cadilacs buzz your seat if they think you are getting sleepy, or is that an obstruction alert while backing up?
