Tapping switched 12 volts in overhead console
Discussion in 'Gen 3 Prius Audio and Electronics' started by lenjack, Jun 24, 2012.
  1. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    '10 Prius 3 without navigation. I would like to access switched 12v in the console. I've taken the console down and removed the connector. Does anyone know which of the wires I need to tap into for this. Also, which wire is ground?
  2. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    I pulled the console down on my 2011 II and did not find the 12v switched in the light wiring.
    If you have a mirror dimmer than it should be there.
  3. gliderman
    gliderman Active Member
    751
    223
    What about the shifer light? Isnt it on a 12v switched circuit?
  4. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    There is no ACC/IGN-ON +12V in the overhead console. The power for active mirror is wired through the A pillar from connectors located under the dash, driver side. The shift knob light is on when headlights are ON. Map/dome lights are powered from +BAT.
  5. lenjack
    804
    114
    Pennsylvania USA
    Where then is an easily accessed swicthed 12v conection.
  6. lenjack
    804
    114
    Pennsylvania USA
    Just realized that I don't need switched 12v. I need the wire in the console connector that goes on with the headlights. Anone know which wire in that harness to use?
  7. gliderman
    751
    223
    That would be the wire going to the ... shifter light?
  8. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    Just open the overhead console, locate the connectors, use the sharp needle as a test point through the cable isolation and measure with a DC voltmeter against some clean metal surface. When voltmeter reading is around 12-14V, you found the power. Test it at different car's mode - OFF, ACC, READY.
  9. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    I just checked the wiring diagram for map light assembly. There should be 20pin white connector U3. The green wire on pin 8 will receive +12V when headlights are on. The ground wire is white-black colored on pin 1.
  10. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    additionally, you can use one of the wires heading for the vanity lights for constant power, for things like Homelink rear-view mirrors. I did this instead of pulling the a-piller cover. these wires were easier to tap than the short cable I had for the overhead console lighting.
  11. lenjack
    804
    114
    Pennsylvania USA
    Many thanks. I am also led to believe pin 20 is also 12v. Are you lookin from the connector side or the wire side?
  12. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    Yes, pin20 is +BAT, pin11 is controlled by door's switches.
  13. lenjack
    804
    114
    Pennsylvania USA
    I very much appreciate your help, but again, I'm not clear on which side of the connector I see in the diagram. I'm guessing that I'm looking at the wire side. Of course, I suppose I could tell from the wire colors.
  14. gliderman
    751
    223
    When messing with electrical parts, you also need a multimeter. That will confirm the output of the power you need.
  15. lenjack
    804
    114
    Pennsylvania USA
    I have one.
  16. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    The diagram is from te pin side, from the wire side it is numbered right-to-left.
  17. Wraiththe
    Wraiththe Member
    258
    49
    Charlotte NC
    I dont get it, for a dash cam you want a wire powered when the ignition is on.
