Tear on my steering wheel
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DirkAshburn, Jan 28, 2025.
  1. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    2011 Prius IV. My steering wheel has worn down on the very top and has about a 2" tear in the leather now. Is there a way to repair this? Has anyone just removed all the leather and replaced it somehow?
  2. Mendel Leisk
    42,360
    Expedient would be to just get a cover?
  3. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    I had a cover on my first car (1989 Ford Escort!) that worn down and hated it, it made the steering wheel too thick and uncomfortable for my hands.
  4. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    If you search, you can find leather replacements. And youtube has a LOT of videos
    of people replacing them. You must have patience, and patience…...
  5. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    Thanks, just watched a few. Yeah I don't know if I have that kind of patience (or skill for that matter). I did see one for a very thin cover, that may have to work.
    ASRDogman likes this.
  6. bbrages
    bbrages Member
    169
    47
    St. Louis
    IMO, replace the steering wheel with a compatible one in good condition. Junkyard or person parting a car out.
    I did this on my Fusion (RIP). It's worth it.
    I messed around with covers on an old Accord I had. Getting a new (good used) wheel is a better fix.
  7. Paul Gregory
    Paul Gregory Senior Member
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I think a restoration specialist would probably cement a patch under the tear, and find a way to close up the gap, while the cement solidifies. How that could be done, I have no idea.
  8. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    I didn't think of that... but how is that done when you have an airbag there? Is it easy enough to switch out? Sounds complicated just thinking about it.
  9. Paul Gregory
    2,340
    614
    Alberta
    2024 Prius Prime
    XSE
    I don't know how difficult it would be to remove the steering wheel cover, but if it's too difficult, I might consider closing the gap with a temporary adhesive while the patch under the tear solidifies.
  10. ASRDogman
    8,067
    4,089
    You could try and auto leather repair shop, or service.
    I knew a man years ago that did that, and it was amazing all the things he
    could do to repair all the stuff. AND, it looked great!
  11. bbrages
    bbrages Member
    169
    47
    St. Louis
    Watch a YouTube on it. Generally it's not too hard. I haven't done a gen 3, but I had to remove my son's gen 2 steering wheel when we did the evap core.
    There will be several electrical connectors. Airbags are pretty easy in my experience. But there is some danger with them.
  12. bbrages
    bbrages Member
    169
    47
    St. Louis
    If you can find one in a self serve junkyard, you can practice on the removal!
