  1. Absolutly Red Hot
    155
    83
    91
    SoCal
    Does Toyota recommend replacing seatbelts after a major rear impact? I was rear ended at 65 mph by a Drunk Hit & Run Driver, $9,000.00 plus in rear end damage. Does anyone have anything on seat belts?
    PS. everyone is sore but still alive and well. My Prius C not so good. Insurance will not Total it, so the repairs will go forward. Only 10,000 miles on it. Hit & Run Drivers Suck!
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Moved from the Prius v forum to the Prius c forum.
  3. rjdriver
    rjdriver Active Member
    406
    168
    Rhode Island
    Sorry about your battered C. Good to hear no one was hurt. It certainly would be good practice to replace the belts and tensioners after such an accident, unless there is a reliable way to test them to be sure they will work properly in the future. But not sure what Toyota standard practice is. Hope all is resolved quickly for you.
  4. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    How do you get rear ended and sustain $9K in damage and the guy who hits y0u is able to drive away from the scene of the accident? Was it an armored car? In any event, if you did not fly into the sea belts and load them up really hard, they don't need to be replaced. Belts need to be replaced it a front end collision when they rub thru the belt holders with so much friction that the fibers in the belt begin to melt. You can actually see the stretch marks in the belt. When hit from behind, the belts receive no stress loading. Your spine, however, likely did get stressed.
  5. CAlbertson
    CAlbertson Member
    99
    24
    If the belts were stressed to the point were yu need to replace them then I'd expect deep bruises on your body from the belts. If you were not bruised by the belts they did not take much force. In a rear-ender I think the seats took the force, then maybe you bounced forward
  6. KaliforniaKid
    KaliforniaKid 2013 Prius v Five 2012 Priuc c Four
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    Actually, the shoulder belts would lock-up on a hard enough hit and should not retract post impact. That's the design and that's when insurance companies are required (forced) to replace them.
    cknfts and RocMills like this.
