Tech stream VIM
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Camry4U, Mar 31, 2021.
  1. Camry4U
    Camry4U New Member
    Batavia,ny
    Has anyone invested in the new Techstream 16.00
    Techstream Vim which requires a interface but can be used with Windows 10. 64bit??
    I have a 2010 Prius and a 2020 Camry Hybrid that I would be able to use it for.
  2. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    no, we just continue to use older pirated or torrented versions free of charge.
    #2 Grit, Mar 31, 2021
  3. Mendel Leisk
    38,709
    can you clarify?
  4. Camry4U
    Camry4U New Member
    Batavia,ny
    Toyota has a new format that will work with Windows 10 64 bit,
    Toyota OTC IT3 Global Techswtream GTS VIM V!6.00.010 OBD II Scanner
    Supposedly this can be run on any Windows 10 computer.
    Just wondering if anyone has heard anything about it or used it.
    I have had very bad luck with the install of 13,14 and cheap dongles.
