[technical] absence of charge and discharge metrics
Discussion in 'Prime Technical Discussion' started by bwilson4web, Feb 21, 2017.
  1. bwilson4web
    15,524
    Driving in this morning after using the BMW i3-REx yesterday, I realized how little electrical information is available in our Prius Prime. Driving down the road, there is no "mi/kWh" like I have in the BMW i3-REx. We only have a projected miles and graphical battery icon. As for charging, both the BMW i3-REx and the Prius Prime have nothing to show how much charge and what profile was used. The owner has to get their own instrumentation. Both of these limitations are silly.
    As I contemplate the problem, I realized this is something that needs:
    1. Independent of OBD - manufacturers are aware of our efforts to find engineering data using the OBD port and the BMW i3-REx will found the 'break-in' alarm if an OBD device is found on the port.
    2. Real metrics - voltage and amps both DC and AC.
    3. Wireless access - it should be as close as your cell phone, pad, or laptop.
    4. SD card access - record the data for offline analysis.
    For AC loads which are the most interesting, these can be gotten without having to modify the wiring using non-contact sensors. DC current is also easily solved but DC voltage is a harder problem. Then using a ruggedized Arduino, the data can be captured and made WiFi available.
    The DC voltage problem may be solvable by looking at the safety interlock plug. Every Prius and the BMW has one to isolate the battery. It may be possible to add a high-impedance sensor in the safety plug but finding a ground reference may be the harder. Also, you don't want even the high-impedance leads leaving the plug but some sort of high-voltage isolation. Not impossible, just an intellectually challenging one.
    Thoughts?
  2. Dmitriy Sokol
    Dmitriy Sokol Active Member
    112
    108
    Annapolis, MD
    You can go into vehicle settings, under Meter Customize and have a mi/kWh (among other info) info displayed next to the speedometer or in the adjacent screen.
    Personally, I prefer the simplicity of the Eco guide and the Eco score, instead of the information overload and doing my own math.
  3. Lemooron
    Lemooron Junior Member
    73
    25
    Lemoore, CA
    As Dmitriy said you can customize the left side of the display using the split screen settings. There is a bar graph that shows mi/kwh on EV mode and MPG on HV mode. It looks like this. P1020211.JPG P1020212.JPG
    bwilson4web likes this.
    49,490
    doesn't the advanced have an app for charging metrics and profile?
  5. Dmitriy Sokol
    112
    108
    Annapolis, MD
    The only charging metric we get in Advanced is amount of miles added. That's about it. I have a ChargePoint at my house and its app provides a lot more details on actual electricity used to charge.
  6. Dmitriy Sokol
    112
    108
    Annapolis, MD
    IMG_7810.JPG Here is another way to monitor your energy consumption for a single drive or a set trip.
  7. bwilson4web
    15,524
    I appreciate the display change just it is hard to do energy studies if there is no record for analysis.
  8. Dmitriy Sokol
    112
    108
    Annapolis, MD
    The only record you can view is daily mi/kWt used for up to a month back.
  9. bwilson4web
    15,524
    I could not get the displays shown on my Prius Prime Plus but I was about to get the "% SOC". Still the problem of getting engineering metrics remains.
  10. Lee Jay
    Lee Jay Senior Member
    5,850
    4,024
    Westminster, Colorado
    Why couldn't you get them?
  11. bwilson4web
    15,524
    It is a Prius Prime Plus, the lowest trim level. Perhaps there is a URL to a YouTube demo of how to enable those displays?
  12. bisco
    49,490
    i'd be shocked if the displays were different acrost packages, but you never know with toyota.
  13. Lee Jay
    5,850
    4,024
    The package doesn't matter, and how to get those displays is in the manual in great detail.
