technical information and compatibility
Discussion in 'Gen 2 Prius Technical Discussion' started by Mehmet alb, Jul 5, 2023.
  1. Mehmet alb
    Mehmet alb Junior Member
    77
    Turkey
    Will 2004-2009 Toyota prius all parts fit 2007 toyata prius vehicle? (including 2004 and 2009)
    Thank you very much
    #1Mehmet alb, A moment ago
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    Same answer as before.
    NO.
    Note: Please do not post the same question in more than one
    sub-forum here. Or on any forum for that matter.
    51,155
    if i recall correctly, there were some changes along the way. you should be able to check part numbers to be sure.
    Mehmet alb likes this.
  4. Carall
    Carall Member
    240
    58
    Harrisonburg, VA
    2004-2005 Prius is a different car. Many parts are interchangeable but even the fuel tank is different than in 2007.
    For 2007 I would use parts from 2006 thru 2009.
    Mehmet alb and bisco like this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Before you guys go flipping out on the OP, keep in mind that he is in TURKEY.
    Those of us that are thousands of miles west of his location are very unlikely to know any minute differences between his exact model and ours.
    99% of the components in the 2004-2009 are interchangeable for the NA model.
    Only NORTH AMERICA got the bladder style fuel tank, so there's one difference. His model shouldn't have the thermos hot coolant tank circuit in the front driver side fender either. Maybe all 2004-2009 are the same in his neck of the woods.
    Thought I read one time that the Gen 3 may have started with the 2009 model year in some places also, so that could have an impact.
    If I remember right the OP is trying to repair some damage on the front driver side from an accident. MOST LIKELY, any 2004-2009 model components will work for what he needs to do, as long as 2004-2009 is a GEN 2 model in his location.
  6. Carall
    Carall Member
    240
    58
    Harrisonburg, VA
    Evap system is different for 2004 Prius and 2007. The engine computer harness is wired differently in 2006-2009 than in 2004-2005.
    The body parts are interchangeable but the style is different ... in North America.
    When installing doors from 2004-2005 prius on 2006-2009 prius make sure you use the door harness from 2006-2009 prius too, because the sound system may not work properly. In North America 2004-2005 prius is not the same as 2006-2009 prius.
