Technical Information Service (TIS) Question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by airliner53, Dec 31, 2007.
  1. airliner53
    airliner53 Junior Member
    17
    If I purchase a subscription to TIS, does it permit me to download and save information, or as an alternative print it out? Is it possible (and feasible) to download the entire service manual for a 2007 Prius?
  2. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Yes, I have done it. But it takes a LOT of time, clicks and locks you to your computer. But at $10 for one day, it beats the heck out of buying the manuals. In fact you can download everything Toyota has, only limited by the time and download speeds.
    I found that downloading the files a .mht was the easiest file format to work with. Watch out for .svg illustrations to make sure that you get them.
  3. airliner53
    17
    Thanks for the info! I am not familiar with those file types, but will do a little research. I don't mind taking a day to download in order to save lots of $$$. I have a rock-solid high speed connection and new PC; hopefully that will help.
