Techstream cable/software and Damn P1377
Discussion in 'Gen 2 Prius Technical Discussion' started by PAULY STAR, Feb 11, 2023.
  1. PAULY STAR
    PAULY STAR Junior Member
    16
    Orange County, CA
    Part 1
    I'm getting dizzy trying to figure out what cable and software and who currently carries it.
    I have a 2005 Prius ~ Windows 11 ~ 64 GB
    Part 2
    This p1377 code is sucking my soul..
    • The only code is this p1377
    • The only light on dash is the yellow with circle brake
    • Checked fuses
    • Swapped capacitor (TWICE)
    • Changed connector (looked a little rusty from water leak)
    • Actuator i changed last summer but hearing that humming and rarely a chirp when i push super hard on brakes.
    im so open to advice and suggestions....thanks
  2. drone13
    drone13 Active Member
    140
    115
    SoCal
  3. ChapmanF
    18,522
    What on earth is telling you there's a P1377 code? There is no such code listed in a Gen 2 repair manual (at least a 2006 edition)?
    You have a brake warning light, and have done a bunch of brake work, but what brake system trouble code(s) do you have?
    Codes from the brake system will be C (chassis) codes, not P (powertrain) codes.
    There is a C1377 code reportable by the brake system, that involves the capacitor module. Is that the code you actually have?
    If so, it might be helpful to edit your post and title (or ask a mod to do so, if your edit time has passed).
  4. pasadena_commut
    pasadena_commut Senior Member
    2,819
    842
    Southern California
    That is what I use now too. The only issue I have had using it is that sometimes the VirtualBox image does not see the miniVCI cable unless I unplug it from the laptop and then plug it in again. There were a few issues during the install of VirtualBox itself, where it wanted some python bits and a VisualStudio runtime installed. Just google the error messages when they pop up and you will find the solutions people have posted.
  5. drone13
    140
    115
    SoCal
    I find if I plug in the VCI cable into the PC before starting Virtualbox and image that it connects every time, but like you saw, if you plug in after the image is running you might have to unplug/replug.
  6. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
