Techstream Calibration Updates?
Discussion in 'Generation 1 Prius Discussion' started by TexomaEV, Jul 10, 2010.
  1. TexomaEV
    TexomaEV Member
    154
    Bonham, Texas
    2001 Prius
    Recently had the chance to see a Techstream Diagnostic PC/Tester in operation on the 2001 Prius.
    Wanted to see what was keeping the TRIANGLE OF DEATH activated. Turns out, someone "ME" didn't flip up the HV disable plug lever on the battery pack.....I felt very stupid to say the least.
    Anyhow, unfortunately the internet was down, and they couldn't look up the following Calibration Flags:
    Engine & ECT:
    14705401
    14705402
    Hybrid Control:
    899834706001
    899814702006
    899814702003
    899814702004
    899814702005
    Anyone know what each of the above deal with, or correct if anything?
  2. TexomaEV
    TexomaEV Member
    154
    Bonham, Texas
    2001 Prius
    Now, I'm really curious about the above, when I accessed this screen, and these codes are showing. Anyone know what they mean? Please reference the attached photo(s)
  3. RobH
    RobH Senior Member
    2,369
    985
    70
    Sunnyvale, California
    I had similar numbers on my Gen2. I hit the clear button, they went away, and now I don't even know what the numbers were. I think the term LAN refers to the audio equipment communications bus. Since no new codes have been set, they must have been something that happened during assembly, or maybe they indicated a problem that was corrected before delivery.
  4. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    the calibration updates i have are only from 07-09 whcih applies to the NHW20 prius im trying to find soemone that has those calibration updates your describing texomaeev.
  5. TexomaEV
    TexomaEV Member
    154
    Bonham, Texas
    2001 Prius
    Thanks in advance for your research.
  6. vincent1449p
    vincent1449p Active Member
    894
    331
    Singapore
    Hi TexomaEV & RobH,
    Pls refer to this pic:
    As for what the code means, pls find the post from rigormortis in the knowledge base:
    http://priuschat.com/forums/knowledge-base-articles-discussion/54408-toyota-prius-2004-2009-lan-check-codes-their-meanings.html
    They are for Gen2 but I 've checked most codes are the same as Gen1.
