Techstream error when registering TPMS sensor IDs
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by BigFan, Nov 26, 2016.
  1. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    While using TIS Techstream V10.30.029 I encountered the error below when trying to add new sensor IDs associated with my Winter tire wheels. I was following the Registration procedure under the Utility menu of the Tire Pressure Monitor ECU
    "ID registration failed due to a communication error with the ECU while in initialization mode."
    This error seems to be persistent, as I retried the registration several times with the same results. The vehicle is on the "ON" state.
    The message goes on to say "Terminate initialization by connecting TC and CG of the DLC3 for 30 seconds"
    I was not clear on what this step was suggesting, but I think is referring to shorting pins on the OBDII connector (seem rather "old school" to me).
    Any recommendations or suggestions?
  2. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Are they Toyota sensors ?
    If not, it could be that Techstream doesn't recognise them.
  3. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Try again in Ready mode.
  4. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    Well when the failure occurred in the "ON" state I switched to the READY mode with the same results.
  5. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    The sensors were supplied and installed by Tire Rack. They are Pacific S122 315 MHz Sensors and are suppose to be Prius compatible.
  6. RobH
    RobH Senior Member
    2,385
    991
    70
    Can you register your old (summer) tires? If that works (they just have to be near the car), then I'd suspect the new sensors.
    RCO likes this.
  7. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    I suppose I could drag the summer tires out of storage to try this, although it is not clear to me the that registration process and the detection of the registered sensor IDs are one in the same. Right now the registered sensors are in fact from the summer tires, but I could see if I can re-register the sensor IDs for these summer wheels.
    Do you think the communication error (above) is between the sensors and the ECU? I was reading this as a communication error between Techstream and the ECU, but it is not clear.
    p.s.: I have sent a note to Tire Rack asking them to confirm the TPMS sensors installed are 2016 Prius compatible.
    #7 BigFan, Nov 26, 2016
  8. Mendel Leisk
    41,898
    How much were the sensors? I'm thinking, and this is pretty Kafkaesque:
    If there's no way in the States to purchase mounted snow tires sans tpms, just do it, and if there's any choices, opt for the cheapest. Then ignore them from there on in, just treat them like regular tire valves.
    Is it still possible to dodge tpms, with loose rims?
  9. RobH
    RobH Senior Member
    2,385
    991
    70
    The old TPMS sensors were working fine. The problem starts with the new ones.
    I've registered a sensor that wasn't even near the car at the time, and it went ok. So it seems strange that you're getting an error so soon. I would expect that you could enter any old sensor number into Techstream. Then if a sensor didn't work, it would complain about something like sensor not found. But the fact remains that the new condition is these different sensors. Sometimes when you introduce an incompatible piece of hardware, the error messages get all wonky. Maybe you've got 2006-2015 design sensors, and they changed something for 2016. I saw a 2016 (2017?) Lexus with "location specific TPMS". Maybe the latest Toyota sensors have changed.
    You can recognize the pioneers by the arrows in their backs. Welcome to the latest technology...
  10. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    RobH - My thoughts as well. This is the first time I have tried using Techstream, but they fact that the error message occurs moments after completing the registration process (i.e., entering the 4th sensor ID) led me to think this was a Techstream issue, not a sensor issue. As previously indicated I have asked Tire Rack to confirm that provided the proper sensor for the 2016 Prius, I could also that the vehicle to the dealer to see if they can register the IDs (but I expect that will cost me some money).
    Worst case I will just live with the dash board indicator light until April with the Summer wheels go back on.
  11. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Techstream 10.30.029? You might try going to a newer version of Techstream, as any Gen 4 Prius support in that version would be very early indeed. (Licensing on the newer versions is pretty annoying, though, in my experience - Windows 10 major upgrades (the ones that happen every 6 months or so) require getting another shady license key.)
  12. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    Thanks for that suggestion. I may give that a try. The retailer I purchased Techstream from did point me to a new version (v11.20.019)
  13. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    I upgraded Techstream to v11.20.19, but there is no change in the behavior (same error message after the last sensor ID is entered). When you begin the registration there is a warning (below) that the registration will fail if "the system is still in the process of initializing".
    I think the fact that the system (tire pressure monitoring ECU/system) is stuck in the initializing process is causing the registration failure. The error message (top of this thread) seems to be saying to connect the Timing Check (TC) pin to the Chassis Ground (CG) for 30 seconds to terminate this initialization.
    As a Techstream newbie I am hesitant on shorting anything to ground. :) I am guessing this means disconnect the Techstream laptop from the OBD-II connector (Toyota calls this the DLC3) and connect pins #4 (chassis ground) and #13 (timing check) together for at least 30 seconds while the vehicle ignition is in the "On" state.
    UPDATE: I found this Toyota TSB that addresses this specific issue (although it is not 2016 Prius specific, so my assumption is the 16' Prius will behavior in a similar manner). I guess I will give it a try. T-SB-0084-09
    #13 BigFan, Nov 29, 2016
    pjksr02 likes this.
  14. Mendel Leisk
    41,898
    I know I'm the TPMS "troll", but doesn't it seem: the problem now is less to do with tire pressures, more a battle with technology?
    Too bad the industry can't standardize the sensors, and allow more than one set of sensors to be registered to the car. Easily, by owners, without resorting to laptops, pirated software. Or some complete paradigm shift, this get's crazy complicated for what it set out to accomplish.
    PaulDM likes this.
  15. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    Yes I agree, there is no reason there cannot be an auto-discovery protocol implemented. (my daughter's 2014 Kia Soul appears to auto-discover TPMS sensor IDs). The good news is I can just ignore the warning indicator and life goes on normally. The engineer in me, however, wants to make this work. :).
    padroo, kithmo, RCO and 1 other person like this.
  16. Mendel Leisk
    41,898
    Yes, I know this phenomena. You'll say, "Ok, I'm not going to get into this too deep, just gonna deal with this little bit.". And a week later, you've completely abandoned restraint, have a bunch of new tools, can't sleep, lol.
    kithmo and RCO like this.
  17. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    That, plus the fact that if you've paid for something you want to use it
    RCO likes this.
  18. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    FYI, I followed the procedure specified in the TSB (T-SB-0084-09) to terminate the Initialization process. While connecting the Timing Check (TC) pin to the Chassis Ground (CG) for 30 seconds did cause the Multi-function display to indicate "DSS Diag" (driver support system diagnostics) it did not allow the subsequent registering of the new TPMS sensor IDs. At this point I will live with the Tire Pressure Warning indicator on the dashboard (until the summer wheels go back on the vehicle).
    Tire Rack confirmed they shipped the correct TPMS sensors for the 2016 Prius. (claiming they are in fact the Toyota OEM TPMS sensors)
    #18 BigFan, Dec 1, 2016
  19. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    BigFan:
    That's a pain. I have not seen that problem on my vehicle even though 2006 Prius is listed.
    One other possible thing is sometimes the miniVCI cables are not quality made and could have solder connection problems. You might want to inspect for defects including the area where it plugs in.
  20. BigFan
    BigFan Member
    156
    66
    New Jersey, USA
    Thanks, I noticed that pins #4 and #5 on the mini VCI (OBDII) connector are pulled forward relative to all the other pins in the connector (i.e, the stick out slightly farther). Is this part of the connector design?
