Techstream Lite interface cable options?
Discussion in 'Gen 3 Prius Technical Discussion' started by PaJa, Nov 16, 2009.
  1. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    I'd like to test my Prius 2010 with Techstream SW using some low-priced interface cable. I do not need the re-flash capability, so Mongoose MFC Interface is quite expensive. What others are using?
  2. rachaelseven
    rachaelseven New Member
    616
    211
    Adams, MA
    Mongoose MFC is the least expensive option that has been reported on the board here.
  3. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    Mongoose!
  4. obidubi
    obidubi Junior Member
    27
    Pennsylvania
    Mongoose MFC works great, puts you in control...:)
  5. pjksr02
    pjksr02 Active Member
    532
    225
    Connecticut
    I haven't seen it specifically mentioned, but would one of Techstream Lite's "reprogramming" capabilities be the TPMS (ie, inputting new TPM serial numbers)?
  6. rachaelseven
    616
    211
    Adams, MA
    Yup.
  7. frenchie
    frenchie Member
    150
    48
    France, not far from PARIS
    Bonjour
    We don't have TPMS in europe, but I confirm that tactrix openport 2.0 works perfectly for most of the functions (for instance reprograming reverse buzzer).
    ordered the 23. received & tested now...:)
    Many thanks to R7
    3 people like this.
  8. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    Good poke, it looks good and for the reasonable price. let us know your findings.
  9. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Frenchie - very nice - I believe that is an open source project (yes?)... Has any of your Euro neighbors tried it with Toyota's Techstreem 4.2?
  10. mastercut
    mastercut New Member
    italy
    @Frenchie , wich software do u use? how much u paide for the shipping to europe?
  11. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    e-shop shows $35-$45 (USPS vs. FEDEX).
  12. rrolff
    1,610
    246
    So Cal
    Have my Tactrix on the Christmas list...
    Per Frenchie on Techstream:
    I use with success rel V4.12.001 on eeePC with XP sp2 or on big laptop with vista.
    I tried also a rel V4.2xxx, working really badly and only on AMD platforms....
    The only option I could not use is "drive recorder" which would be very interesting
  13. sfritzinger
    sfritzinger New Member
    NV
    Dealer just told me they could neither turn off the back-up beeps or the passenger seat belt beep due to safety concerns and liability issues. This is the downside of living in a single-dealer town.
    Has anybody else, in addition to frenchie, confirmed that the Tactrix OpenPort 2.0 cable will work with TIS to at least disable both of warning beeps? For the cost, it seems like an incredible deal (PassThru support and all).
    I'm thinking that if someone else confirms it, I'll pick one up and help out anybody locally wanting to disable them.
    If nobody else confirms, I may just buy it anyways and post findings.
    Thanks!
  14. rrolff
    1,610
    246
    So Cal
    I have it on order - but it's on the Christmas list, so I won't be able to play with it until after the holidays... Frenchie reports it does program the reverse beeps etc.
  15. rrolff
    1,610
    246
    So Cal
    The Cable is around $200 delivered - not $500...
  16. rrolff
    1,610
    246
    So Cal
    Techstream can be found in the internet world - Google is your friend...
    The cable I bought for $200 is the Tactrix - not Mongoose.
  17. Larry Beard
    Larry Beard New Member
    Corinth, MS
    Can someone confirm the Mongoose/Techstream lite scantool system will connect and show trouble codes in between the times your TIS subscription is active? Thanks in advance!
  18. The Critic
    The Critic Resident Critic
    3,193
    2,319
    CA
    Bump. Has anyone else had more experience with the Tactrix cable?
