Techstream not connecting to VIM
Discussion in 'Gen 2 Prius Main Forum' started by Sharnold, Sep 23, 2019.
  1. Sharnold
    Sharnold Active Member
    394
    123
    Alabama
    Tried hooking my laptop to a Prius that's lit up like a Christmas tree with DTCs my techstream would not connect also tried another scanner it returned no codes. I checked fuses all good. Obd2 port pins good. So either I'm having techstream issues or something is not right with the obd2 port on the car.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    My guess would be driver issues. Are you sure you have the right drivers properly installed for the OBD2 cable you're using to connect the laptop to the car?
    Sharnold likes this.
  3. Sharnold
    394
    123
    Alabama
    I've been using this laptop for over a month with techstream no issues until now so I'm lost. I'm going to try it on another Prius this evening but I'm afraid it's going to be the computer not the car. I had mine set up remotely
    Skibob likes this.
  4. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    Driver issues?... ...Oh, you mean COMPUTER driver issues! :cool:
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    @Sharnold
    One thing that I've run into previously with techstream:
    Warnings sometimes pop up that it cannot "connect to the network". This is referring to the Toyota Network. If this occurs, don't select "try again". There should be another selection similar to "continue". Select that and the program will stop trying to connect to the Toyo network. It's best to have the laptops wireless system disconnected. If it currently connected to wireless when techstream starts, it will try to update and lock up the program.
  6. Sharnold
    394
    123
    Alabama
    My wireless is disconnected this is what's popping up even after rebooting the computer IMG_1697.jpeg
  7. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Can't provide any help on that one that you haven't already mentioned. I've been fortunate enough where I've never run into that pop-up.
    I think you're right about it just trying it on another car. At least then you'll know whether its a cable problem or a car problem.
    Skibob likes this.
  8. Sharnold
    394
    123
    Alabama
  9. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    There are a lot of discussions in PriusChat and the general internet about that error. I searched for "Unable to connect to VIM", and many articles came up that have solutions which involve the actual program installation or moving some of the files around. When I purchased my version, it came with instructions that were part of the CD. I printed them out and I consider myself lucky that I was able to follow them well enough to get mine to work, especially with 64 bit. I'm not computer literate enough to understand some of what they discuss in those articles. Hope you have better luck.
  10. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    It tried to phone home and it bricked the program. Uninstall the program and reinstall it. It’s happened to me before also. Never try to start techstream when you have the internet connected.
    Also I don’t think version 8 would connect to a 2016. Try version 12
    Free Download and install Toyota Techstream 12.20.024 on Windows 7 | OBDII365.com Official Blog
    I like this version better than the ones that manipulate the keys. This version has a 4 thousand something day expiration date instead.
    #10 Skibob, Sep 23, 2019
    SFO and jerrymildred like this.
  11. Sharnold
    394
    123
    Alabama
    I'm not on version 8 I'm on 12 picture was just for reference but I appreciate everyone's imput. Mine has 4900 days on it
  12. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    This reminded me to check mine....now I'm depressed...wonder if it will reset if I reload from the CD? Anyone know?
    Anyone familiar with both Ver 10 and Ver12? Better, worse, indifferent?
    Skibob likes this.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    We tried a newer version and the functionality was worse (I want to say it was version 13 something):cool:.
    I went back to 10.30.028 and haven’t looked back;).
    I’d say re-up with that(y).
    Skibob likes this.
  14. Sharnold
    394
    123
    Alabama
    I've got a note file that came with mine on the disk on how to restart the days on the older versions I'll take a picture later and post it. As stated mine started with 5000 days
  15. jerrymildred
    11,517
    14,137
    Tampa, FL
    In the old days of Window$, you probably would have had to find the date in your registry since that wouldn't always get removed by the uninstall. Not sure with newer versions. But I'd guess there's something in the system that has that record which the uninstall will leave behind to prevent people from getting around it like that.
    Edit to add: However, I made the mistake of hitting the wrong button on my old version of TS and it started a countdown saying I had X number of uses left. That went away by itself when I installed a considerably newer version to be able to talk to the Prime. This is on XP running in Virtual Box on an old Linux laptop with the wifi turned off by a physical switch.
  16. Skibob
    2,912
    1,502
    Northern California
    Never tried 10 myself but if I could get it to program the TPMS sensors I’d be all in.
    Raytheeagle likes this.
  17. Sharnold
    394
    123
    Alabama
    This is what was in my notes for older versions for day reset in notes
    You can reset your day countdown by
    Going to C:\Toyota Diagnostics\techstream \Env
    And find the "It3usercustom.ini"
    File and look for "connectioncount=1" or whatever number of times you tried and just delete "connectioncount=1"
    Click save and it should reset back to 30 days
    jerrymildred likes this.
  18. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    This is how my version resets the connection limit. Many versions (mine included) only let you connect 30 times. Once I get down to about 5 left, I use the above procedure to reset the count down counter to 30
  19. Sharnold
    394
    123
    Alabama
    Sorry I didn't know if it was for day countdown or connection
  20. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    I’ve programmed keys with it, probably can do TPMS sensors with the ID’s too;).
    Really good tool to have around(y).
    Skibob likes this.
