Techstream reinstall?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Andrew Vanis, Oct 1, 2023.
  1. Andrew Vanis
    Andrew Vanis Junior Member
    34
    Albuquerque
    (Edit, this is about Techstream local software not TIS on-line service. Edited title. Discussion about Techstream starts on Post #7))
    (if there is a topic on this already, please direct me, the search did not yield an obvious result)
    The XP laptop I got from a prior Prius owner that had the factory software was stolen from my Prius. Luckily they did not take the cables or CDs (pic).
    Hard to find XP laptops these days.
    What's the best way to proceed to get back to detailed Prius info?
    Thanks
    #1 Andrew Vanis, Oct 1, 2023
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,591
    6,644
    Texas Hill Country
    Get a used win7 laptop with a good battery
  3. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Do you currently have a laptop (or tablet) with a compatible USB port?
  4. Andrew Vanis
    34
    Albuquerque
    yes have laptop(s) with w10. thought TIS needed XP.
    What OS(s) will the TIS work on?
  5. rjparker
    10,591
    6,644
    Texas Hill Country
    Some have activated on win10 after some singing and dancing at the file and registry level:
    How to Install Mini VCI Techstream on Win10 64bit?
    Others simply buy “Professional” rights for two days ($70) and go legal assuming their hardware interface can do it
    #5 rjparker, Oct 1, 2023
  6. ChapmanF
    18,607
    Little naming point:
    TIS is the name of a web online service you can subscribe to for manuals and service literature.
    Techstream is the name of the software you put on your laptop to talk to the car.
    Official Techstream only works while you are subscribed to TIS, so a little confusion is understandable, but they're different things.
  7. Andrew Vanis
    34
    Albuquerque
    thanks, this is what I am inquiring about. Updated the title.
    1) what OS(s) can it be installed
    2) Where can I find instructions on how to install on said OS(s)
    Thanks,
  8. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Any OS that can run virtual box, or a windows device. You will need a USB port as well for that dongle.
    There are many all over the web, and this blog has quite a few write ups for TS : https://blog.obdii365.com/?s=techstream
  9. Andrew Vanis
    34
    Albuquerque
  10. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Which oddly enough is also the exact same link that @rjparker offered in the above post #5 : Techstream reinstall? | PriusChat
    Have you already attempted to follow the previously offered (and now found again) installation instructions, did they work?
    If you're having issues installing (or don't have a cd-rom drive), here is a "preinstalled image" of TS (via that same blog) that you can run inside of the "virtual box" app. Lets us know if you find yourself stuck in either of the processes.
    Lloyd-ss likes this.
