techstream user, good battery then p3000 and p0A80 EVERY 1-2 WEEKS
Discussion in 'Gen 2 Prius Technical Discussion' started by scottyj, Sep 19, 2020.
  1. scottyj
    scottyj Junior Member
    seattle
    I GOT P3000 WITH BLOCK 14 LOWEST
    I GOT P0A80 WITH 14 LOWEST
    I HAVE TESTED THIS BATTERY WITH HOBBY CHARGERS DRAING THEM TO 6.2VOLT AND CHARGE THEM
    I HAVE LOAD TEST EVERY CELL WITH A 50AMP LOAD TESTER .. ALL OF THEM HOLD ABOVE 7.2 VOLTS FOR 5 SEC
    IS IT THE BATTERY
    THE ECM
    WHEN I SEE LIVE DATA all cell/blocks ar with in .30 volt of each other
  2. SFO
    SFO Senior Member
    5,286
    4,226
    Northern California
    PriusCamper likes this.
  3. PriusCamper
    PriusCamper Senior Member
    10,933
    4,427
    Pacific Northwest, USA
    I live south of you in Olympia... One of the two modules in block 14 has a cell that is starting to fail, but hasn't failed completely... Usually its moduel #28...
    Figuring out which of the two modules, replacing it, then reconditioning whole pack is next step.
    Charging up all modules to max charge and then measuring voltage after a few days (self-discharge test) may help you find which module it is.
    Alternatively, if you're just driving around town and can quickly clear the codes in a way that doesn't complicate your day too much, you can wait till the bad cell gets worse and is easier to identify...
