Techstream
Discussion in 'Prius c Main Forum' started by Javierz0509, Jan 13, 2018.
  1. Javierz0509
    Javierz0509 Member
    111
    52
    Miami
    So I got this on eBay to give it a try, where can I get more info on how to use it for the prius c, like what to look for?
  2. ChapmanF
    15,476
    Well, plug it in, fire it up, have some fun turning your lights, fans, and pumps on and off from your laptop, and when that gets boring, put it away and wait for a problem with the car; then you'll know you can pull up the diagnostic codes and freeze frame data to help track down the problem.
    -Chap
    wenreder, RobAustin and Javierz0509 like this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,194
    5,891
    Columbia, SC
    You'll need to place the CD into your computer and follow the directions provided to install the software package. After that, all you have to do is connect the OBD end to the car, the USB end to your computer, then start the software. Then just follow the prompts provided by the software.
    Javierz0509 likes this.
  4. Steve Morris
    Steve Morris Junior Member
    Melbourne
    ----Australia----
    I have been reading through the threads (I think it's called threads) and thanks for providing the photo of what Techstream, so I purchased this. A scanner is very expensive and to buy a scanner - they seem like a hit and miss accuracy, also the lists are not always recorded and/or provided when investigating capabilities etc.....there's so much information when it comes to Techstream and hopefully I can figure out how use this too.
  5. Danny Campos
    Danny Campos Junior Member
    Los Angeles
    Hello Prius chat forum. Where can I get a copy of the techstream software?
  6. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Some questions:
    • Do you have a J2534 protocol dongle already?
    • What vehicle are you looking to use this for as that may affect the version you choose?
    • How much are you looking to spend?
    I have an old laptop paired to a mini vci setup running Techstream version 10.30.029. I paid $20 for this on amazon (had the old laptop, so that was free).
    There can be challenges when installing the software on the laptop, but it can be done;).
    Good luck and keep us posted (y).
    SFO likes this.
  7. hassan310
    hassan310 Junior Member
    29
    PK
    Is there any option to find total distance traveled? In case of prius 4 gen you can see in data list. But I'm not sure about prius c. I'm using techstream 12.00.24
  8. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    No idea. I’d just run through the menus and see what you get;).
    Why is this number of interest to you? Did someone mess with the odometer? Other damage to your c?
  9. Kyle McDowell
    Kyle McDowell Junior Member
    Iowa
    check obd365.
    be sure to follow the instructions on how to install it. v13 or 14 should work for a 2010.
