Temperature gauge for outside temperature
Discussion in 'Gen 5 Prius Main Forum' started by Ngenovesi, Mar 23, 2024.
  1. Ngenovesi
    Ngenovesi Member
    50
    27
    Pittsburgh
    2023 Prius Prime
    I am finding the temperature gauge that says what the outside temperature is , is way off. It was 28degrees F. The displayed showed 34. This is after driving in that temperature for 20 miles. It appears that the lower the temp the worse the difference is. Can dealer check this. Not sure if this a big deal or not to have checked out.
  2. PriusCamper
    PriusCamper Senior Member
    11,104
    4,518
    Pacific Northwest, USA
    Yeah... Let them know... It's the only way to get your money's worth when you buy brand new. With the amount you paid I'd be making their service department work on even the tiniest problems as often as possible.
  3. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    They can test the probe to make sure it works, and they can verify that it is mounted correctly, because position matters for those things.
    Lastly there is an electronic setting- a fudge factor to offset an error elsewhere.
    One way or another they should be able to fix you up.
    TGrracie and PriusCamper like this.
  4. Mendel Leisk
    38,727
    Based on an actual, accurate thermometer, your phone's weather app, or?
    PriusCamper likes this.
  5. Ngenovesi
    Ngenovesi Member
    50
    27
    Pittsburgh
    2023 Prius Prime
    Actual weather app
  6. Mendel Leisk
    38,727
    Weather app's thermometer might be far enough away to be a few degrees different from your location.
