ten speakers in prime advanced
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Diemaster, Nov 24, 2017.
  1. Diemaster
    Diemaster Active Member
    290
    260
    so. cal
    this has been driving me crazy. the web says the advanced with premium JBL comes with 10 speakers, but i cant find 4 of them. there one in each door and the 2 up on the dash by the windshield. but if i do have premium (witch with advanced i should) i cant find them.
  2. Inza2
    Inza2 Member
    43
    106
    Netherlands
  3. Diemaster
    290
    260
    so. cal
    thank you for that. i can safely assume that the normal prius and the prius prime have the same setups right?
  4. Tideland Prius
    16,155
    10 speakers in 6 locations as the graphic above shows. I guess this is so that they don't have to make two versions of the door panels (like they did for the Gen 2 and Gen 3 Prius for the rear tweeters).
    Yeah the locations and type of speaker should be the same between the Gen 4 and Prime.
  5. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    Looks like front and rear speakers have 2 driving units inside, which is not rare.
