Terrible off alignment after ball joint repl
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Georgios, Sep 17, 2019.
  1. Georgios
    Georgios Member
    126
    85
    Chicago
    I have replaced the ball joints and the sway bar links on the Prius (old ones had torn boots) and I installed new rotors and pads too. Once I put everything back together both wheels are pointing inside pretty severe with steering wheel centered. I have Not removed the tie rod ends at all! And now few lights came on and as far as they know the car knows it's out of alignment. I didnt attempt to drive it ofcourse.
    What should I do? Should I turn the nuts on the tie rod ends and make the wheels somewhat straighter so I can drive it 3 blocks to the alignment shop?
    For reference about 6 months ago I replaced both front wheel bearings and I back then have removed the whole spindle from the tie rods and everything and when I put it back together the alignment was almost perfectly stright. I still did an alignment but nothing was so bad. And now not even removing the tie rods at all can cause this???
    Thank you
  2. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    Maybe ball joints are wrong type? With new ones being shorter? Or they are installed wrong on the lower control arm? Don't turn the tie rods or drive it as that can damage your driveshaft or transmission.
  3. Georgios
    Georgios Member
    126
    85
    Chicago
    Therr is no way ball joint is installed srong. They are not directional
  4. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    If only three block to the alignment rack I think you would be inclined to drive it there. Otherwise call a hook and have them deliver it there for you. Ball joints are a suspension wear item but I haven't witnessed the extreme effect of toe-in replacing them as you have pictured. No chance in not installing both front wheels cock-eyed.? I know its a stretch and clearly you are comfortable around wrenching on cars so no insult intended. Just looking for easy simply explanations.
  5. Georgios
    Georgios Member
    126
    85
    Chicago
    Thank you
    I realized now they sold me ball joints for 04 Rav 4. Unbelievable. They fit and look almost identical. I will now install the correct ones and see if i have done any damage to the rack even if i didnt actually drive it
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    @valde3 absolutely NAILED IT!!
    Well done!!
    Skibob and edthefox5 like this.
  7. valde3
    2,002
    746
    Finland
    What I ment was that you could maybe install it wrong in lower controll arm so that only 2 of 3 bolts would alighn and with the wrong bolt holes.
    No you shouldn't! If wheel alignment is off do to ball join wheel (and knuckle) is also too far or close to knucle. That can break the driveshaft or transmission.
    It's very common to get the wrong part. Often it happens multiple times in a row. You just need to check your parts carefully.
    If it feels normal when you turn the wheel by hand turning (both front wheels of the ground) there should be no damage to driveshafts. And transmission damage is very unlikely if you didn't drive it. No other parts can't really be damaged because of that.
  8. Georgios
    Georgios Member
    126
    85
    Chicago
    So problem is solved.
    Yes parts were wrong(for Rav4) but i installed them correct and the 3 bolts alligned on the wrong part too. How wierd
    Now i got the correct ones and the tires are pointing straigh. Drove it on the driveway and no noises. I didnt want to drive it on the street because those lights came on and i have to look for my VCDS cable to reset them. If i cant find it i will try the scangauge2
    Picture for refference:
    The left ball joint is the rav4 and the right 2 ball joints are for prius2 - one is oem used one is aftermarket.
    Very easy to tell which is which when you look at the top bolt (red circles)
    The rav4 design is pretty much a triangle around the top bolt while the prius part is much like an oval
    Thank you guys for the time and help
    Mendel Leisk and Raytheeagle like this.
  9. Mendel Leisk
    40,584
    Geez they are pretty close.
  10. ilbdarned
    ilbdarned Junior Member
    Arizona
    The ball joints they sold you for the Rav 4 also fit the 1st Gen 2002 and prior year Prius . I know because I had the same issue after installing them on my Gen 2 Prius.
    They just sold you the wrong Generation Prius ball joint.
    #10 ilbdarned, Jun 18, 2025
