Test-driving a Prius
Discussion in 'Gen 2 Prius Main Forum' started by jsuh84, Dec 3, 2007.
  1. jsuh84
    jsuh84 Junior Member
    22
    Chicago
    For those with the experience, what should I keep in mind when test-driving a Prius?
    Some issues that I have concerns include the rear window and highway driving (Crosswinds, switching lanes with its supposedly sensitive steering, music).
    Any others I should keep in mind?
  2. john1701a
    john1701a Prius Guru
    12,761
    5,247
    57
    Acceleration is so smooooooth (no gear shifting), it gives you the impression that you aren't going as fast as you actually are.
    As for the rear window, 99 percent of viewing is through the upper section. Think of it as a bi-focal, were the lower section is used only for up-close viewing (like parking).
  3. Tideland Prius
    16,220
    Note that the Touring edition may ride differently than the standard Prius. The suspension is tuned differently and the Touring edition has larger/wider wheels/tyres so make sure you know which one you're testing.
  4. cuttooth
    cuttooth Aficionado
    32
    Calgary, AB
    Avoid salesman accompaniment if at all possible. It made my test drive difficult at the best of times.
    I'm trying to drive the car, not your profit margin!
  5. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    If you have a large frame (like me), you might consider renting one for a couple of days and taking it on the road. You may not get a good sense on a typical test drive of how comfortable it will be on long trip. The seat bottom doesn't adjust, and thigh support for some of us long-legged folks could be a little better.
    To piggyback onto John's comment, I call it "sneaky quick." I liken it to an elevator. Because the speed transition is smooth, you don't fully appreciate the acceleration, at least not like the abrupt change folks are more accustomed to with a conventional transmission.
  6. jsuh84
    22
    Chicago
    I'm actually new to the car-buying experience. This will be my first auto purchase.
    Do most dealers, specifically Toyota, allow people to test drive by themselves?
  7. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    657
    262
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Not around by us. The salesman was sitting in the back seat. At least this one fairly knowledgeable.
    One thing to check, is the rear visibility on the highway. It's not the best, and should be considered.
  8. Spinnerbug
    Spinnerbug New Member
    28
    Lincoln University, PA
    My daler gave me the car for two days...I test drove it to work on a Sunday, loved it and ordered it on Monday. I have a fully loaded Acura TL and am selling it. The only option the Prius doesn't have that my Acura has is heated seats and I could have got that, but figured I would let them go. Did get XM radio though. I am getting my new Prius next week...:)
  9. Tideland Prius
    16,220
    Depends on the dealership. Some allow you to test drive on your own, others require a salesman.
  10. la cucaracha
    la cucaracha New Member
    60
    Austin
    I test drove a Prius from a Tx dealer for 2 days. They never asked of a deposit and did not call to see how things were going. I called them and said I was going to buy it in a couple days and they said great. I had the car 4 days total with no deposit and put about 100miles on it. I did buy it.
    They size you up, no doubt. If you go to a dealer that will not let you have a reasonable test drive..leave.
  11. richard schumacher
    7,663
    1,040
    United States
