Test drove a 2024 Prime
Discussion in 'Gen 5 Prime Charging' started by beef jiggles, Dec 18, 2023.
  1. beef jiggles
    beef jiggles Member
    135
    34
    Colorado
    It was right off the truck, 4% battery. Super slow, slower than my 2017. I assume this is common on low battery?
  2. Hammersmith
    Hammersmith Senior Member
    1,305
    1,331
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Short answer: Yes.
    Try another test drive later when the battery is up to a decent charge. Doesn't have to be 100% or anything, but at least 25% so the car has some battery power to work with during accelerations.
    49,371
    shouldn't the battery give the same power in hybrid mode as ev mode?
  4. KMO
    KMO Senior Member
    1,506
    385
    Finland
    2023 Prius Prime
    That's nonsense. Anything above EV 0% has loads of battery available, and most of the way through the HV buffer will still give you full acceleration.
    You have to actually deplete the HV range to reduce power output.
    Here's a video with someone demonstrating the same acceleration with 54% and 0% EV range.
    Back to the OP, maybe the car was in EV mode? A G5 in EV mode is probably slower than a G4 in HV mode.
    Or maybe you just weren't pressing the pedal enough? Was it in Eco mode, making the pedal less responsive?
    Or, conceivably, if "right off the truck", is there any sort of software limiter for the first couple of miles, that would resist someone immediately flooring it - a forced break-in period? Not aware of such a thing, but possible.
    Did anyone here try flooring theirs with 5 miles on the clock? I didn't...
  5. Hammersmith
    1,305
    1,331
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    When they said 4%, I assumed they were talking about the complete battery, not just the EV range(as in all the EV range was gone and almost all of the HV range was gone as well due to discharge from shipping). If they had the full HV buffer and 4% EV range on top of that, then I would agree that my post was nonsense. But what else would account for an extremely sluggish Prime?
  6. beef jiggles
    beef jiggles Member
    135
    34
    Colorado
    Break in periods really aren't relevant combustion engines built in the last decade.
    The car I test drove wasn't in EV or eco mode that I'm aware of, but all I did was start it and go. Even in ECO mode, my 2017 will apply full power, you just have to press the pedal further.
    The car I drove had 16 miles on it. I know how a gas pedal works, this had to be the battery charge... that's the only thing producing noticeable torque. It said 4% where it reads a number, whatever that means. I wasn't in the car long enough to datalog all the different widgets and bullshit on the screen but it was SLOW.
    #6 beef jiggles, Dec 18, 2023
    Beach Dweller likes this.
  7. HacksawMark
    HacksawMark Active Member
    439
    287
    Oregon
    2023 Prius Prime
    XSE
    Yeah there is no way a G5 is slower than a G4.
    Danno5060 likes this.
  8. KMO
    KMO Senior Member
    1,506
    385
    Finland
    2023 Prius Prime
    The G5 can default to EV mode from startup - it will be in AUTO EV/HV if it was turned off in that mode, otherwise it will be in EV, unless the EV range is at 0%, in which case it will be HV.
    And if it is in EV mode, full pedal pressure won't engage the engine - the power is limited to halfway through the "PWR" range on the hybrid gauge.
    So I think the most likely scenario is that you did "start it and go", it was in EV mode, and it was fast enough for you to not realise that, and think it was just slower than a G4 overall.
    It is possibly true that a G5 starting up in EV mode will be slower than a G4 starting up in EV mode, if you floor it, because the G4 will engage the engine for more power.
    If you want full hybrid power to be available in the G5, you need to be in AUTO EV/HV or one of the other modes. Fortunately the EV vs AUTO EV/HV choice is remembered across power cycles, so your preferred behaviour sticks.
    Edit: actually, maybe this doesn't make sense - I was thinking of European G4 "EV Mode" behaviour, which is different from the US's...
    #8 KMO, Dec 19, 2023
  9. Mr.Vanvandenburg
    1,027
    350
    2020 Prius Prime
    Electronic brake on?
  10. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Butt-dyno's have been shown to be very inaccurate. Got data?
    "I wasn't in the car long enough to datalog all the different widgets and bullshit on the screen but it was SLOW."
    OK.
  11. beef jiggles
    beef jiggles Member
    135
    34
    Colorado
    Engine was running.
  12. beef jiggles
    beef jiggles Member
    135
    34
    Colorado
    Im not dumb guys, floored it and it was dreadfully slow. At a ¼ mile on ramp and it barely hit 50 MPH
    #12 beef jiggles, Dec 19, 2023
  13. HacksawMark
    439
    287
    Oregon
    2023 Prius Prime
    XSE
    Unbelievable
  14. Mr.Vanvandenburg
    1,027
    350
    2020 Prius Prime
    It’s electric parking brake, not electronic as I said. Maybe the person jockeying the car on the truck manually set the brake and you didn’t release it? That’s the only reason I could think of. “All I did was start it and go” It’s nothing unusual, how many times do people do this? Lots of times.
    Maybe that’s why they have an auto mode and manual mode for the parking brake. In auto the car releases the brake. It must be because they felt in manual people would forget to pull up, or push down, on the switch to release the brake.
  15. KMO
    KMO Senior Member
    1,506
    385
    Finland
    2023 Prius Prime
    Was it still attached to the truck? Did you notice anything in the rear-view mirror?
    dbstoo, Rafsdhc6 and AndersOne like this.
  16. reallyreal
    reallyreal Member
    68
    56
    Italy
    2024 Prius Prime
    If you are talking about P, doesn’t it get automatically switched off when you engage D or B?
  17. Mendel Leisk
    38,644
    I wonder about some of these new "features". I've had a little experience with electric parking brake on a Mazda CX5; found it maddening trying to determine if it was set or released, and how to reliably accomplish either state. Oh and when I replaced rear pads on it, struggled for about an hour till I discovered the chicken-dance required to retract the piston.
    I'd put it in the same category as touch-screen controls on the dash, of benefit primarily to the manufacturer.
  18. beef jiggles
    beef jiggles Member
    135
    34
    Colorado
    JFC, Im not an idiot.
    If the parking brake was on it would not have moved from the parking spot without some seriously noticeable issues.
    #18 beef jiggles, Dec 19, 2023
  19. Mr.Vanvandenburg
    1,027
    350
    2020 Prius Prime
    Electric parking brake set to manual mode, not P.
  20. Mr.Vanvandenburg
    1,027
    350
    2020 Prius Prime
    The brake on was just a suggestion of the cause btw. If I was asked if I could have left the brake on I would write, I remember yes I released it. There was no criticism involved, just a suggestion.
