the 12 volt outlet
Discussion in 'Gen 3 Prius Technical Discussion' started by Jim Calvert, Sep 16, 2009.
  1. Jim Calvert
    Jim Calvert New Member
    255
    28
    Worthington, Ohio
    Does the front 12 volt outlet have power after turning the vehicle off? Thanks.
  2. marzprius
    marzprius Junior Member
    92
    Northcoast
    nope!
  3. jayvee
    jayvee Member
    341
    89
    WA
    Hi Jim,
    From the owner's manual, page 379:
    [FONT=Arial,Arial][FONT=Arial,Arial]The power outlets can be used when [/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]The "POWER" switch is in ACCESSORY or ON mode. [/FONT][/FONT]
    [FONT=Arial,Arial][FONT=Arial,Arial][/FONT][/FONT]
    [FONT=Arial,Arial][FONT=Arial,Arial](Please don't take offense, but was this question really postworthy, when it could be answered so easily from the user manual, or just by plugging something into it and turning off the car?) Just my two cents. I'm no moderator.
    [/FONT]
    [/FONT]
  4. Jim Calvert
    255
    28
    Worthington, Ohio
    Thanks for the quick reply. I was just wondering. The decades old cigarette lighter design, as best I remember, always had power - probably because the car manufacturers did not want any smoker to have to endure a "nicotine fit" if they had to take the time to turn on the ignition before they could light up. ;)
  5. Jim Calvert
    255
    28
    Worthington, Ohio
    Sorry. I looked for it in my manual but missed that page somehow, and I don't have any devices that I could plug in - at least until today when I purchased a 12 volt charger for my cell phone. It doesn't include an LED to show that it is on, so I wasn't sure whether I had power at that outlet or not.
    Anyway, thanks for the page number.
  6. jayvee
    jayvee Member
    341
    89
    WA
    Understood. Again, no offense. (FYI, your cell phone probably has a battery indicator icon that has a lightning bolt (or similar) when it is plugged into a charger.)
    Yes, I think most of these outlets are now "switched". Kind of a pain, but probably too many car fires, and the lawyers got involved. There have been quite a few occurrences of lithium-ion batteries (like those used in cell phones) catching fire when they go bad.....
    I would like to have at least one unswitched, too...
  7. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    GM's are still unswitched I believe
  8. milkman44
    milkman44 Active Member
    591
    386
    Ky
    I want to either add another outlet that is always hot, or make the outlet under the bridge hot when car is off. I don't have a problem finding a place to put an extra outlet, but if somebody has already done this, where can I tap always hot wire under the dash or do I have to go to the fuse panel? Sure would help if someone has done this with directions.
  9. El Dobro
    El Dobro A Member
    6,972
    3,209
    Nope, power off, socket off. I think the reason for this is so people don't deplete the battery by leaving things plugged in and running or charging when the vehicle is parked.
  10. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Our '04 Saturn has two sockets that are always live...I really miss them in the Prius; I always had a fully charged cell phone.
  11. fuzzy1
    10,044
    More likely, back then they didn't have many plug-in accessories that could deplete the starting battery. The lighters themselves automatically shut off when heated. I didn't even think of the issue until the 12V coolers came along. Leave one of those things plugged in overnight while camping, and bye-bye battery.
    While setting up dad's GPS in his Jeep, I found that it had two sockets on the console, one switched, the other always hot.
  12. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    On the other hand, if you leave the car's ignition on, you can draw power from the 12V outlet for over a week. There are people who attached 110VAC inverters to the Prius 12V battery to power campsites or even their homes for several straight days.
    The high voltage battery will keep the 12V battery charged, and if/when the high voltage battery depletes, the engine will automatically start, charge the high voltage battery, and shut itself off.
  13. ETC(SS)
    6,494
    Correct.
    IIRC you can't lock the car with the fob with the IGN on, but I think you might be able to manually lock it...if you're inclined to do so.
    GM's 12V outlets are unswitched (as of '09) but the battery in my dumb old pickemuptruck is a little more robust than the one in my G3. I have 2 cell phones that have been left plugged in for 3-day weekends with no problems.
    I don't think that the 12V outlet is considered by the vehicle's power management system. I can leave my radio, lights, etc on for about 15-mins, and then the truck says "OK....that's enough!" and shuts down those circuits, so it might be possible to deplete the battery through the 12V outlets.
    Still....I MUCH prefer their layout---especially considering the automatic lights....but that's a different story. :cool:
  14. Southern Dad
    Southern Dad Active Member
    350
    212
    58
    Monroe, GA
    I would also love to have an always hot 12 volt outlet in the Prius. Since neither my Insight nor my G2 Prius had one I've got used to it though. I keep a Power Jolt for my iPhone plugged in. Before someone asks why I don't just plug in the iPhone, this is for when I'm out and about. No plug handy. You simply take the fully charged Jolt with you. It will add 10% or more to my iPhone battery.
    Only my Lincoln Navigator has always hot outlets. However, I do enough driving that the Jolt usually stays pretty well charged up.
  15. stevil
    stevil New Member
    Denver, Colorado
  16. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Hmm, people still want to fully drain the tiny Prius battery?
  17. johalareewi
    johalareewi Member
    393
    44
    uk
    On the gen3, there is an always hot 12v on the main connector into the radio/cd unit. Just pop out the head unit (5 min job) to get access to the connector. You can find the +12v lead very quickly with a voltmeter (and the car off). From memory it is a greyish green colour and is one of the thick wires at the end of the connector. Not sure if it is fused or not but it is not switched.
  18. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    When the Gen 2 came out, there were a lot of cables (even from Coastaletech) to make the front wire hot- it was just a wire with 2 clips on it. I have one in my 2005 Prius.
    Hoping that the 2012 PIP can get it too since having it aways hot is nice for charging that cell phone (I have 2 that I carry and sometimes they fight for the charger).
  19. Joe166
    Joe166 New Member
    720
    96
    South Florida
    My 2004 Ford TBird has always hot power outlets. Anyone dumb enough to leave anything with a lot of power demands plugged in deserves whatever happens to them. I prefer to be trusted to unplug things. As it is, the switched power outlet in my Prius (and in my Lexus CT200) means my IPhone discharges overnight so I turn it off and remove it, which further means that unless I remember to turn it on before I start the car up, the contacts and speed dials get erased every single time and have to be reloaded.
  20. hlunde
    hlunde Member
    419
    74
    I had thought about using a small "battery maintainer" solar collector whenever the Prius is parked for an extended period -- outdoors of course. Without an always-on 12 receptacle this becomes a bit more complicated.
    I could tap into the dome light circuit since a number of us have discovered the hard way that this is always on!
