The $166.00 Halogen Head light?
Discussion in 'Gen 2 Prius Main Forum' started by rjmiz, Aug 7, 2007.
  1. rjmiz
    rjmiz New Member
    Today I noticed the passenger high beam is out on my 2007 with 16,500 miles on it. (funny, but I didn't notice it while driving) Truth be known the high beams are so bright that while driving, you can't tell the lights out!
    Anyway the point of this post is that I read on another forum a gentleman complaining that his drivers side was out, and that it was going to cost $166 to replace because they (the service dept) have to take off the front bumper cover to get around the fuse box. (I think I quoted him correctly)
    Is this true!? Are we all doomed to eventually pay the money we all saved in gas back to Toyota some day?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    I thought they were more expensive to replace than that. I'd be pretty dang pissed if I had one go out at 16,500...would be talking to the dealer and calling Toyota to see if they'll cover part of the cost...but i don't think it's covered under any warranty.
  3. bobdavisnpf
    bobdavisnpf Member
    149
    Yes.
    On the plus side, this is no different from any other modern, well-equipped car. And it's not some conspiracy to gouge us, either: we're just packing more/better/fancier technology to a smaller and smaller space.
  4. rjmiz
    rjmiz New Member
    AHHHHHHHHHHHHhhhhhhhhhhhhhhhhhhhhhhhhhhh!
  5. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    uhhhhhhhh
    first, this will be covered under the 3/36 warranty. next, you just reach back and change the damn bulb. like any other car. you remove the bumper to remove the headlamp assy or the hid computer.
  6. Tideland Prius
    16,445
    huh? can't you just replace the bulb?
  7. KTPhil
    KTPhil Active Member
    1,379
    Guys, the title of the thread is "The $166.00 Halogen Head light?" These aren't HIDs.
  8. dogfriend
    7,512
    1,189
    Carmichael, CA
    If you look in the Owners Manual, there are instructions to replace the headlight bulb. You have to remove the plastic piece above the grille, but you should be able to remove / replace the bulb without removing the bumper cover.
    If you need to remove the Headlight Assembly (the housing) then you have to remove the bumper cover as Galaxee mentioned.
    The owners manual says its an HB2 bulb. Isn't that commonly available at any auto parts store?
    http://www.truckcustomizers.com/products/R4HLA131.5B.html
  9. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    That's crazy! On all my other cars you can get to the headlight bulbs very easily. I think its rather poor engineering by Toyota.
  10. ZA_Andy
    ZA_Andy Member
    219
    VA
    <div class='quotetop'>QUOTE(Texas911 @ Aug 8 2007, 09:28 AM) [snapback]492322[/snapback]</div>
    What's hard about access as per the descriptions given for replacing the bulb already posted? Doesn't seem a problem to me.
  11. YoDaddyAlex
    YoDaddyAlex Member
    271
    not poorly trained, they just know how to get more cash out of people who come in for service without said customer knowing the truth
  12. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    Go and try to access the bulbs and then tell us its just as easy as reading it on the manual. It isn't.
  13. rjmiz
    rjmiz New Member
    "Go and try to access the bulbs and then tell us...."
    Whoa! ....I really want to change the Toyota Prius bulb again.... just like I'm looking
    froward to squeezing my fingers in a vise some time soon.
    93 degree weather, hot and humid. No where in the manual did it illustrate, or indicate
    that you must have the hands of a five year old child before proceeding.
    (Tip: when you change yours, observe the way it comes out) There is one tab on top, and 2 on the bottom.
    It took me an hour, but now that I know what I'm doing (through trial and error) I think I can
    change the next one in 55 minutes flat. It's a tight squeeze to maneuver around in there.
    I have had more headaches with the Prius headlamps right from the beginning. From being
    aimed too high, and bringing it back to the dealer 3 times for adjustments, just to wind up
    adjusting them myself finally.(300 miles traveled)... to the bulb burning out at just over 16,000 miles.
    There's no question in my mind, the next time I pay a mechanic for sure!
  14. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    This is not unusual. Even much larger vehicles (the anti-Prius for example - 2001 Pathfinder) can be a bear to change headlamps. It used the same bulbs as the Prius, 9003 or H4. First, remove the battery (for the right side), or the airbox, (for the left side). Good thing they don't burn out very often. Even with DRLs. The bulb, BTW, is only $10 or so.
  15. dogfriend
    7,512
    1,189
    Carmichael, CA
    Japanese engineers probably have smaller hands than North American car owners (on average). :)
  16. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I think they are a pain on all newer cars, the wifes beetle isnt an easy change and I recently did my sister's Mazda and it still ended up being a 45 minute hassle.
  17. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    Confusing posts....
    If it's the high beam halogen, its about a $10 bulb and it can be replaced by any shop, or you can do it yourself very easily. Reach behind the headlight bucket and unplug, remove and replace. Don't touch the glass! It's a standard HB2 bulb. I'd be surprised if any incandescent bulb like that would be covered under warranty.
    If it's the FOG light, then yes you have to disassemble at least part of the bumper assembly. Kind of a pain. Again it's a 9006 HB4 bulb , about $10, but the labor is going to be big if you have the dealer do it.
    If it's a HID headlight, it should be covered under warranty since they are expected to last the life of the car.
  18. Wildkow
    Wildkow New Member
    5,270
    37
    36
    <div class='quotetop'>QUOTE(morpheusx @ Aug 8 2007, 02:30 PM) [snapback]492650[/snapback]</div>
    Clean the bulb with an alcohol pad somethimes grease from your hands gets on the bulbs and they don't like that one bit at all, no siree! May not help because that advise is usually for halogen bulbs but what the heck it can't hurt and what better excuse do you need to bust open that headlight one more time!?!? :lol:
    Wildkow
  19. Tideland Prius
    16,445
    <div class='quotetop'>QUOTE(ZA_Andy @ Aug 8 2007, 07:10 AM) [snapback]492334[/snapback]</div>
    Obviously you've never attempted to change the bulbs in the Prius. It's a PITA to replace/change the bulbs. Go try it yourself.
  20. ZA_Andy
    ZA_Andy Member
    219
    VA
    <div class='quotetop'>QUOTE(Tideland Prius @ Aug 9 2007, 01:00 AM) [snapback]492857[/snapback]</div>
    What I said was: "What's hard about access as per the descriptions given for replacing the bulb already posted? Doesn't seem a problem to me."
    Now if you have information that specifically indicates why the descriptions re changing the bulb given earlier in the thread are not accurate and that therefore it is harder than implied, that would be helpful.
