The 2 things the Prius could use improvement on..
Discussion in 'Gen 2 Prius Main Forum' started by ElectricMayhem, Sep 6, 2008.
  1. ElectricMayhem
    ElectricMayhem New Member
    Crosswinds.
    Driving through the plains states, you can really feel the crosswinds a lot.
    I guess it's such a light car, and the aerodynamics are mainly for the front>back, but it maybe needs a tweak in that dept.
    I may eventually try the stiffening plate. Some say it works, some say it doesn't do much.
    When I have a few bucks to play around with, I think I'll give it a try.
    Battery on hills.
    On a 10,000+ mile road trip, I averaged well over 40 mpg the whole time, and that was with 2 ppl in the car and literally as much stuff as we could possibly fit. The only time I got worried was on some long hilly stretches, when it would drop to 1 battery bar & kind of dog a bit.
    It was never a real problem, but a bit more capacity would be nice.
    Or even a way to switch to a battery preservation mode, where it would focus more on battery level than mpg while it's engaged.
    Those 2 things really are minor though, and it's BY FAR the best car I've ever owned.
    I read some peoples posts that said it's more of a practical car than a touring car, and I disagree. I LOVE driving it.
    I have the touring model, and it handles beautifully on winding coastal roads and in nat'l parks.
    And around town it's like a little shuttlepod. : )
  2. smsprague
    smsprague New Member
    Tucson, Arizona
    I will give you 3:
    1. Offering an 8 way power adjustable drivers seat.
    2. Dusk/Dawn sensing headlights.
    3. Auto Door locks once the car starts moving.
  3. ElectricMayhem
    I can see where people of different shapes & sizes might have trouble with the seat, but it actually fits me like a glove. Just lucky I guess. There must be a bunch of engineers in Japan that are my exact size. =P
    As for the other 2, I like to be in control more than the car. If they add those options, I hope there's a switch or software option to disable them.
    It does have an auto-off feature on the lights, which is good though.
  4. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Mayhem, get your alignment checked carefully. That helps quite a bit.
    I also saw a big improvement when I swapped the Goodyear Integrity tires (at 25k miles) for 195/60 Michelin Hydroedges.
    As for your battery experience on the hills:
    1. The Prius will take care of the battery automatically; no need for a "battery preservation mode." Just let it do its thing.
    2. The Prius is not a truck. You were probably exceeding its weight limit---810 pounds for the 2006.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Hmmm...have never seen one bar on my 07 trucking along..only when stuck in stop go traffic with ac on. But even then it charges real fast back up to 3 bars when you start moving. One bar huh? Maybe its like the previous poster said max load stressing it out. Not a truck,...well put. Be careful because if anythings getting stressed its the MG's. Be good to that trans and change the fluid often 'cause your super duty'ing it.
  6. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    Huh? Haven't auto on/off headlights been mandatory for years? The Prius doesn't have automatic headlights?
  7. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    The lights turn off when you stop the engine with the power button. If you leave the light control 'on' they will of course come on when you start the car. He was talking about a sensor to make then come on at dark and go off at daylight automatically like alot of US cars. You see them do that in car washes and tunnels and such. The Prii doesnt do that. And no there is NO law about that. shouldnt be either.
  8. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    Every car I've owned in the last 13 years has had an auto on at night headlights.
    The Prius doesn't have this????? My dealer just called today, btw, and the Spectra Blue touring I've been waiting to show up in their allocations showed up yesterday.
    I have to say though, between the lack of adjustable driver seat, no telescoping steering wheel, and this, no auto on headlights at night(I'm not going to leave them on during the day because they lower MPG), I'm having serious second thoughts about getting it. How can the Prius have so many high tech gadgets but be missing basic features that are available on the prius in every other market.
  9. darelldd
    6,057
    389
    Northern CA
    Not that I'm aware of.
    Depends on what you call automatic.
    My big issue (and it is with just about ALL cars!) is that NOTHING should stay on for longer than say 15 minutes once the thing is powered down. No interior lights should stay on no matter what you do after turning the car off. In other words, no car should allow the Aux battery to drain because of one mistake of leaving a door open, or an interior light accidentally turned on (and yes, I know the door lights turn off in the Prius - but not the hatch!)
  10. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    Back to the OP's subject I say the biggest flaw with the Prius is the OEM Goodyear Integrities. They really are an embarrassment of a tire to be stuck with on a new vehicle (Prius or even one of the hundreds of other cars that come with them).
    Another feature I would like to see is a grill with automatic grill blocking that automatically opens and closes. For example it would start opening to allow in some air before the fans would turn on and start closing to maintain an optimal engine compartment temperature.
  11. smsprague
    Tucson, Arizona
    Of the 3 improvements I mentioned above the power adjustable seat with driver memory would be the most important. It is a feature I would really like and be willing to pay for. Don't get me wrong I still think my Prius is a great car and would recommend it.
    I am thinking of getting new tires eventhough the car only has 1100 miles. Hard to justify, but it sounds like it would make a big difference.
  12. ElectricMayhem
    I felt the same way for a minute (partially b/c it took almost a month..), but once I got it, it was even better than I expected.
    I swore to myself that I'd never buy an automatic car. In all the ones I've driven before, it never felt like I had as much control as I do w/ a manual transmission.
    But the Prius is different. Maybe it's b/c of all of the feedback you get on the screens (which all become second nature after a bit), but I really feel like I'm driving the car, and in automatics I usually feel like the car is driving me.
  13. ElectricMayhem
    Oh, and as for the tires, I have the touring so it doesn't have the integrities.
    I think they're Bridgestone.
    But I'd definitely like to try out a different brand when it's time to change em.
  14. kenmce
    kenmce High Voltage Member
    1,527
    502
    NY
    1.) Pull the climate controls back out of the MFD. Have physical knobs on the dash so you can work them by touch, like any other Toyota.
    2.) Have a trunk hatch release handle by the drivers seat and a mechanical keyhole on the hatch.
  15. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    Put on a set of Michelin Primacy MXV4s and suddenly, you won't find the decision hard to justify at all. The GY Integs are a pox on both Toyota (for installing them) and GY (for putting its name on them). I've had them on several new Toyotas, and one way or another, they all got replaced early. Check out a dismounted Integ -- the sidewalls have the approximate thickness and consistency of a rubber raincoat. Scary. No wonder they handle so poorly...
  16. darelldd
    6,057
    389
    Northern CA
    Oooh. I'll give you another vote for that one! I find it comical that for "safety" I can't use certain features of the MFD while driving (blue tooth, NAV, etc). But climage!? Sure, go ahead and take your eyes off the road while fooling around with those settings. No problem!
  17. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Absolutely.
    My '04 Prius has dash plastic that does not wear well, and tends to squeak. I don't hold it against Toyota because they were using plant based materials, but hopefully it is improving. On the topic of the dash, material that absorbs heat in the winter and deflects it in the summer would be nice. An additional layer to use part of the year would be ok too.
    A different upholstery. Mine is just too plasticy.
    As much attention to wind flow under the car as above.
    Manual vertical height adjustment in the drivers seat.
    As you well may imagine, this car as it is now barely rates a 9.5/10.
  18. edselpdx
    edselpdx Member
    191
    Portland, OR
    I'd rather be safer and run my headlights during the day (makes you more visible to other drivers in ALL weather) than save a few 10ths in my MPG. The only time I turn mine off is when I'm going to be sitting for a few minutes in park listening to the radio while waiting for someone or waiting for the end of a radio story or something.
  19. SageBrush
    11,627
    2,530
    Southwest Colorado
    Are people finding it difficult to turn the lights on/off manually ?
    I'd hate to be paying that person's home electric bill.
  20. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi EM,,
    Since you have the 16 inch wheels and the Bridgestones, alignment should be double checked next.
    I would also recommend the BT Tech brace. The BT Tech brace makes the car much more linear in response to steering command. The main impact is that it reduces the magnitude and duration of that tail-end vibration. So, when you feel where the car is, that is where it is. Without the brace, you need to average a few vibration cycles, over about a second, to know where the car is.
    Ex-SUV, Pickup and Van drivers do not have a problem with that vibration. But small car/ sports car drivers just cannot stand it. Me included.
