the Alarm System
Discussion in 'Gen 3 Prius Main Forum' started by alj65aedeker, Jun 19, 2009.
  1. alj65aedeker
    alj65aedeker New Member
    Long Island New York
    Does anyone know if the new alarm system offered as an accessory for the 2010 Prius besides sounding the alarm for a break in or broken glass, gives any additional protection then the engine immobilizer that already comes with the models? For instance Toyota advertises that the alarm system has a set of rolling codes?
    What does that mean anyway? Obviously, a pro is going to pull the car onto a truck and take it if they want the car bad enough.
    thanks
    Aljaedeker
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    As far as I know, it only adds the alarm noise if the glass is broken or a door or hood is forced open. The engine immobilizer is standard and unaffected.
    As you said a pro is going to get your car if they want it, so I passed on the alarm.
    The rolling codes are similar to those on modern garage door openers, so a person with a scanner can't capture your code and use it later.
  3. alj65aedeker
    Thanks
