The annoying "backing up" beep....
Discussion in 'Gen 2 Prius Audio and Electronics' started by AOV, Jul 14, 2007.
  1. AOV
    AOV New Member
    302
    Poughkeepsie, NY
    I have only had the car for a few months...and I go out of my way to park it so I would not have to reverse out of the parking space, but that is not always an option....so help! :blink: I know its been done, not sure where to look...and it has to be in layman's terms, I don't understand any other language.
    Thanks.
  2. SureValla
    SureValla Member
    590
    Shelton, CT
    Turning of the Beep
    try that site. I recommend printing it out and having someone read the directions to you as you attempt it. Make sure they arent sitting in the car as the instructions mention.
    It took me 3 tries to do it but I'm really glad I did
  3. orionll
    orionll Active Member
    1,115
    Here is a link to darelldd's website's instructions on how to disable the beeper: http://evnut.com/prius_beeper_disable.htm .
    And a quote:
  4. AOV
    AOV New Member
    302
    Poughkeepsie, NY
    <div class='quotetop'>QUOTE(SureValla @ Jul 14 2007, 07:38 PM) [snapback]478815[/snapback]</div>
    Thank you!
    <div class='quotetop'>QUOTE(orionll @ Jul 14 2007, 07:42 PM) [snapback]478816[/snapback]</div>
    Sounds easy....Thank You
  5. brianguy
    brianguy New Member
    <div class='quotetop'>QUOTE(AOV @ Jul 14 2007, 04:33 PM) [snapback]478814[/snapback]</div>
    I Googled "disable prius backup beep" and quickly found the instructions here:
    http://www.wikihow.com/Disable-Reverse-Bee...-a-Toyota-Prius
  6. noelty
    noelty Member
    112
    Los Angeles
    I have followed the directions ten times...and I still cannot get that darn reverse beep to disable...it is driving me nuts!
  7. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    <div class='quotetop'>QUOTE(noelty @ Jul 14 2007, 11:09 PM) [snapback]478991[/snapback]</div>
    In step 5 above, count to 30. Holding it too long won't hurt, holding it not-long-enough prevents the operation from working. I'm not sure, but I think the doors need to be closed too, since shifting out of Park with the car Ready usually causes warning noises if the doors are open.
  8. noelty
    noelty Member
    112
    Los Angeles
    <div class='quotetop'>QUOTE(Bill Merchant @ Jul 14 2007, 11:22 PM) [snapback]478997[/snapback]</div>
    Doors were closed...I'll go ahead and give it the 30 second shot in the morning.
  9. Godiva
    Godiva AmeriKan Citizen
    10,339
    Be sure you're sitting in the drivers seat and not the passenger seat.
  10. adchesney
    adchesney New Member
    I spent about two hours trying to get this work..I thought I MUST be REALLY STUPID!...then I found out you can't disable this on the UK version :-(
    Regards
    ANDREW (UK)
  11. AOV
    AOV New Member
    302
    Poughkeepsie, NY
    <div class='quotetop'>QUOTE(noelty @ Jul 15 2007, 02:09 AM) [snapback]478991[/snapback]</div>
    I did it! I thank you, my passengers thank you, everyone thanks you. :D
    Though, it took 3 times. I was sitting in the drivers seat, closed door, open windows (hot). The part that I was doing wrong was step #5. It says to press WITHIN 6 seconds..."Within" being the magic word, I took too long to do that.
    ....and reading further on, for those who still can't do it...this is important...."This sequence will not turn the beeping off for the European version of the Prius".
  12. drdwilcox
    drdwilcox New Member
    Peoria, AZ
    My friend has a 2004 Prius, not European, and we are having trouble getting this procedure to work. Anyone know if it works on the '04? I know it is the new style.
    Thanks,
    Don
  13. noelty
    noelty Member
    112
    Los Angeles
    <div class='quotetop'>QUOTE(Don Wilcox @ Jul 24 2007, 10:20 AM) [snapback]484191[/snapback]</div>
    I too am still having problem on my 07 package 6 Touring. I foolowed the directions and advice here and simply have given up. I no longer use reverse. ;)
  14. B Rad
    B Rad New Member
    295
    A year ago when I bought my PRI the 1st thing I did was turn off the beeper using the methods mentioned in the above posts. Then I bought a small little round beeper from Radio Shop. I accessed the right rear back up light from inside the trunk and connected the little beeper to it. Now I have a much quieter beep-beep coming from the rear of the car. You can control the volume by insulating the beeper until you get the desired volume......
  15. drdwilcox
    Peoria, AZ
    While my friend has an '04, I have an '07, and I was able to get it to work after about 3 tries. I even got the passenger seatbelt warning to silence as well -- now I can carry my laptop with having to belt it in!
    Keep trying.
    <div class='quotetop'>QUOTE(noelty @ Jul 24 2007, 10:28 AM) [snapback]484195[/snapback]</div>
  16. noelty
    noelty Member
    112
    Los Angeles
    <div class='quotetop'>QUOTE(Don Wilcox @ Jul 27 2007, 04:33 PM) [snapback]486419[/snapback]</div>
    I finally got it...now to disable the seat belt beep.
  17. box
    box New Member
    Thank God for the search feature.
    I actually disabled my reverse beep through a faulty search. Haha, I was looking for a how-to on installing a sub, and ended up disabling the beep instead.
    I'm happy with it being off. :)
  18. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    If the beeping really bothers you, maybe the radio isn't loud enough. Seriously, I was backing my car into the garage, and jumped out to open the garage door, and forgot to put it in park. As I momentarily started to get out, the beeping, which I normally filter out caught my attention, and I grabbed Park. Sometimes the beeper is your friend. For most people, it sounds like not.
  19. ny biker
    ny biker Member
    463
    Northern Virginia
    2022 Prius
    <div class='quotetop'>QUOTE(subarutoo @ Jul 31 2007, 03:56 PM) [snapback]488253[/snapback]</div>
    I was just going to say -- am I the only person here who is not annoyed by the beep?
  20. RobertG
    RobertG New Member
    166
    Northern California
    <div class='quotetop'>QUOTE(nybiker @ Jul 31 2007, 01:43 PM) [snapback]488273[/snapback]</div>
    No, you are not.
