The "B" Gear
Discussion in 'Gen 2 Prius Main Forum' started by DanCole42, Apr 21, 2005.
  1. DanCole42
    DanCole42 New Member
    24
    Arlington, VA
    The manual doesn't make it clear, so I'll ask around. What exactly is the "B" on the gear selector for? I know when I use it, the car slows down considerably. Does this improve the regen braking? Does it affect gas mileage? In what sorts of instances do people use it?
    Thanks!
    -Dan
    AIM: TheEmperorOfRome
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    do a search on B Gear and read up. Thousands of lines have been devoted to it.
  3. richard schumacher
    7,663
    1,039
    United States
    It's to avoid riding the brakes when going down a long hill, equivalent to putting an old-style transmission in 2nd gear. It mostly reduces fuel economy so avoid using it otherwise (not living near mountains, I've never used it).
  4. NuShrike
    NuShrike Active Member
    1,378
    I use so I don't ride my brakes down a long hill, coming off the freeway, or when I need that extra stopping power as part of emergency braking.
    Just like S-mode on my Civic cvt.
  5. spknicks
    spknicks New Member
    West Chester Pa.
    Use Engine Braking as often as you can! It is like putting your old automatic trans into a lower gear, use it like you would use a manual trans down shift, such as slowing down before stopping. [font=Arial:58e09c3489]Now here is the best part "Engine Braking" sends kinetic energy to run the electric motor and what is not needed to run the electric motor is stored for future use!!![/font:58e09c3489]
  6. Tideland Prius
    16,161
    Hey there spknicks. Careful though. That'll only work at 35km/h and lower (using the generator). Any speed higher than that and it's use the engine itself to slow you down and that's just wasted energy as the pistons pump up and down.
  7. spknicks
    spknicks New Member
    West Chester Pa.
    yep, you are correct! thanks (I knew that! lol)
    along that same vein, slower stops and slower starts does the same thing, uses kinetic energy to run the electric motor and stores the extra in the batt. (less gas engine running = more MPG)
  8. gschoen
    gschoen Member
    343
    Chicago/Wrigleyville
    2014 Prius Plug-in
    B Mode will make absolutely no difference in emergency stopping distance. Emergency stops use good old regular, reliable friction brakes.
    Riding your brakes on the Prius won't cause brake fade, unless you're pressing down hard enough for friction brakes (regen braking doesn't heat brake pads) or your battery is completely charged and won't accept any more juice.
    You won't get any more regen using B mode than using your brakes. There will be more regen when you lift your foot from the pedal, but you can get the same level of regen still with the brake. You will get lower MPG since your engine will be spinning more, and coasting is far preferable to regen for MPG.
    There are very few instances B mode is needed for safety. It certainly doesn't offer any MPG improvements, usually it's for novelty or driver comfort (traffic, less pedal switching, etc.)
